I have a few dozen DV tapes I captured a few years ago in Premiere Pro. They were captured as AVI files which are no longer compatible with newer versions of Premiere because of Apple's change over from 32bit support to strictly 64bit software support.
Does anyone know of a way to convert these files without having to reencode them to ProRes or H.264?
In other words can they just be rewrapped in a new container or something? I don't want to lose any quality with a reencode because I'll need to edit and color grade this footage.
The AVI files themselves don't care whether the operating system or the applications are 32-bit or 64-bit. They are media files, they are not software.
If I am not mistaken, the MOV container supports the DV codec, so you could remux the AVIs to MOVs with ffmpeg (for example).
However I don't know whether the software you want to use accepts DV-in-MOV"Programmers are human-shaped machines that transform alcohol into bugs." -
Also, fyi Premiere on Mac is and has been 64bit for a while. And unless I am mistaken, it no longer relies on QT/AVfoundation to parse & import into the app - they use proprietary 3rd party tools.
NicePlayer 64bit mac app being planned(I hope)?
By Philatley in forum Newbie / General discussionsReplies: 0Last Post: 4th Dec 2019, 17:52 -
StaxRip v2.0.0.1 Beta fails to convert .avi files
By RHawk in forum Video ConversionReplies: 4Last Post: 13th May 2019, 00:44 -
How to multiplex avi files on linux/mac/windows? (command line)
By Selur in forum Newbie / General discussionsReplies: 4Last Post: 27th Jan 2018, 08:30 -
Best software to convert Canopus AVI files to H264/MPG4 format?
By Studly in forum Video ConversionReplies: 9Last Post: 9th Nov 2015, 14:36 -
Help!!!! Convert to DVD on my crappy MAC
By Lugger067 in forum MacReplies: 3Last Post: 6th May 2015, 14:50
