I only want to capture VHS tapes on my PC and then encode then copy to Video CD to save storage space.
Which Video Capture Card should I get to do this?
The amount of video I want to capture is 240 mins, is it possible to span this across 3 to 4 80 min CDR disks?
System Info
Packard Bell Club 550
550 MHz
AMD-K6-2 with 3D Now
64MB RAM incl. 4MB Shared Video Memory
15 GB UDMA Hard Disk
Miami motherboard
Windows 98 SE
SiS 530 Graphics Card
Thanks, Ross Mitchell
Your system is a bit limited, so I would suggest capturing VHS at 352x240 (352x480 and use vertical reduction in Vdub). Your system will not be able to capture anything bigger than this. Also, with only a 15 gig hard drive, you will have to compress the video quite a bit.
I would suggest you get a hardware encoder. For VCD creation, get the PV231 (needs PCI slot). It should work perfectly on your system, and can capture 4 hours without getting into the 4 gig limit. Cineplayer Editor and MyFlix can cut the file into 80 minute chunks.
The other option is to get WinTV or ATI Wonder VE, which both needs a PCI slot. However, your CPU and hard drive is a limiting factor. -
Thanks for the info skittelsen, can you buy this PV231 video capture card in England, should I capture in NTSC or PAL as PAL is what we use in England.
I also have a Dansai 1010 DVD player, what make of CDR would work with this.
Would the Snazzi 1 video capture card work with my PC, I have a DVD which I want to record 1 hour of footage from, could PV231/PV233 or Snazzi 1 be able to copy DVD.
Can I buy any of these video capture cards from England or USA.
Thanks, Ross Mitchell 8) -
just a friendly suggestion... but upgrading your RAM and graphics card will make a WORLD of difference to your system.....
I have been wanting to upgrade my RAM for 2 years now but I dont know how much to buy for desent video capture.
Same goes for a new graphics card as well. -
You can pick up a Geforce 2 quite cheaply now, as for RAM, the simple rule is.. you can never have too much!
I actually have a system similar to your's (but it's 450 MHz and 192MB of ram) and got the 32MB ATI AIW PCI. It cost me about 200 (American Dollars). I know it captures NTSC, but I believe it also does PAL. Just make sure that the video card you are getting is PCI and not AGP, otherwise it will not fit.
Hello.I am trying to do the same as RM01 is.My old computer fried so i'm looking to have a new one built.Can anyone suggest what i should have,P4,ddram,? gig h.d.,capture card,etc.I too was limited on my old comp. and did not get very good results when using creative's analog to digital bridge. I have lots of vhs tapes to convert and just want to keep the same picture quality.Thanks for the help.
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
So... what's new with PC video capture cards this year?
By c627627 in forum Newbie / General discussionsReplies: 131Last Post: 24th Feb 2011, 00:20 -
How can I use multiple usb video capture cards on one computer?
By gbenson in forum Capturing and VCRReplies: 0Last Post: 27th Jan 2011, 20:47 -
1080i video capture - is there any cards at a reasonable price
By mikesbytes in forum Capturing and VCRReplies: 7Last Post: 1st Feb 2008, 15:53 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05
