Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 67
  1. Originally Posted by TubeDigger View Post
    Originally Posted by Angel_Cyclops View Post
    Bad news(for me): Moreover some of the sites wont launch on tubedigger either.
    May you provide names of these sites and explain the purpose of such your statement?
    feneodotin. Site I got the link from is one. Shows an empty screen
  2. Indeed i have the full version of Allavsoft and i can confirm they dont get downloaded with the url's that you have provided maybe they will fix it on the next update
  3. Originally Posted by ChezBompaLawijt View Post
    It happened this morning when one of my friends called. He sent me the link to check if I could dl. Dont think its a fault with the program. More to do with sprout probably updating the security protocols. In any case, allavsoft has ceased to support browser extension and video resolution as their CC confirmed.
    If anybody could show me how i can dl using youtube-dl(or streamlink or ffmpeg). Problem is, Ive learnt bits and pieces from different places, so its all become very vague to me.
  4. Originally Posted by Angel_Cyclops View Post
    If sprout made new changes to there setup then Allavsoft needs to adjust there program to to download again from sprout like all other programms/tools
  5. Originally Posted by Angel_Cyclops View Post
    Or your video card is old or perform Windows Update and also update all your drivers.
    Otherwise install other version of TubeDigger with older Chromium 56.
  6. Originally Posted by TubeDigger View Post
    I just to download occasionally and need a tool to be able to download. Ytb-dl and these CLIs seems to be the most hassle-free.
  7. Originally Posted by Angel_Cyclops View Post
    Before you admired other downloader...
    In case of empty screen in embedded browser - TubeDigger has also button "Monitor Browsers" that allows to detect videos from Firefox/IE browsers.
  8. Originally Posted by LZAA View Post
    Url?
    Were you able to download?
  9. Originally Posted by TubeDigger View Post
    Understand this, Im here to download videos - not pick a fight. Now I dont know whether you are as your id might suggest, a representative of tubedigger, or simply a fan; I simply stated what is. My pc may be 10 years old, but things have been running smoothly till now. Moreover as I had clearly mentioned in my first post, I have IDM which I use for 95% of my work. For the rest like sprout, I use between Applian, Tuberdigger, apowersoft, allavsoft, getflv, stream video and a few others. Of all these, its only tubedigger that said sites didn't load. What I saw is what I said.
  10. Originally Posted by Angel_Cyclops View Post
    I am the owner of TubeDigger.
    Before you said that TubeDigger works with a mind of its own, now it didn't load sites. New versions of Chromium may not work properly with old video cards, but TubeDigger has also embedded Internet Explorer browser and specially for old video cards I keep version of TubeDigger with older Chromium 56 (may also be used for wider selection RTMP sites).
    And from TubeDigger's welcome screen:
    If video cannot be displayed - switch to Chromium3 browser in settings dialog
    Or press button "Monitor Browsers" and open that video in external Firefox
  11. press button "Monitor Browsers" and open that video in external Firefox
    For example:
  12. Thanks for that, but please dont bother yourself too much on this. Ive been using a trial version of this program contemplating whether I should buy it. Its just too much hassle, especially for an old pc like mine is. It keeps downloading CEF75 and after 1 hour Im at 37%. When it works its a good program though Im now looking for a more cash-free option since I usually dont download everyday. So if anybody can help with CLI, please do.
  13. 1 hour for 22MB?? and you're only 37%???
    what connection do you have ??
    I was you more than worrying about the PC i would think of a better connection ....
  14. Originally Posted by lomero View Post
    Not a very high speed connection, but still 5mbps. Im not worried about my pc or my connection. At this moment Im looking for ways to download sprout. Hopefully allavsoft will reply soon and come up with some patch.
  15. Member Emeritus
    May 2014
    I dont see an fbsig on firefox. Would that matter, so long as I see the signature and expires values?
    At minimum, the very end of the base64 data must have "mobile":true and not "mobile":false or else the mp url will never work, even if "signature" and "expires" values are present.
    If "mobile":false is in the data, a suitable mobile user agent isn't being used when playing the embed url.
  16. From 02/06/2020 it stopped working. 'true' in place.
  17. Originally Posted by ponens View Post
    <!DOCTYPE html>
    <html lang="en">
      <head>
      <title>Sauda Bhabhi S01E02</title>
      <!--[if IE]><script type="text/javascript">document.documentMode<9&&(document.location.href=document.location.href+(/\?/.test(document.location.href)?"&forceIE8=true":"?forceIE8=true"));</script><![endif]-->
      <meta name="ROBOTS" content="NOINDEX, NOFOLLOW">
      <link rel="prefetch" href="https://images.sproutvideo.com/a2f584d9e601b00466e8287a4070a02a/862f379ddb270f37bf1e30e11cf0a89c/poster_frames/frame_1581058204.jpg" as="image">
      <link rel="preconnect" href="//d1ajyp3swh7ygp.cloudfront.net">
      <link rel="preconnect" href="//hls2.videos.sproutvideo.com">
      <link href='https://fonts.googleapis.com/css?family=Open+Sans' rel='stylesheet' type='text/css'>
      <link href='//d1ajyp3swh7ygp.cloudfront.net/hls_player-6c3c9ed5.css' rel='stylesheet' type='text/css'>
      <!--[if IE ]>
      <style type="text/css">
        .player-subtitle-cue {
          font-size: 2em;
        .player-select:before {
          display: none;
      </style>
      <![endif]-->
      <script type="text/javascript" src="https://ff.kis.v2.scr.kaspersky-labs.com/7543CFE6-63AF-FA4D-943D-4FDE59702A07/main.js" charset="UTF-8"></script><script type="text/javascript">var dat = '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';</script>
      <body>
        <div class="player paused sd no-cc   " style="background-image: url('https://images.sproutvideo.com/a2f584d9e601b00466e8287a4070a02a/862f379ddb270f37bf1e30e11cf0a89c/poster_frames/frame_1581058204.jpg'); background-size:contain; background-position: center;background-repeat: no-repeat;" aria-label="Video Player" role="main">
          <a href="#" target="_blank" class='player-call-to-action' style='display:none'>
            <div class='player-call-to-action-text'></div>
            <div class='player-call-to-action-arrow'>
              <svg viewBox="0 0 31.28 48.71" xmlns="http://www.w3.org/2000/svg">
                <path d="m30.82 26-22.41 22.46a2 2 0 0 1 -2.71 0l-5-5a1.85 1.85 0 0 1 0-2.71l16-16.07-16-16a1.85 1.85 0 0 1 0-2.71l5-5a1.76 1.76 0 0 1 1.36-.68 1.74 1.74 0 0 1 1.35.6l22.41 22.4a2 2 0 0 1 0 2.71z" transform="translate(-.08 -.29)"/>
              </svg>
            </div>
          </a>
          <div class="player-big-play-button" role='button' aria-label='Play Video' tabindex='1'>
            <svg viewBox="0 0 26 30"><polygon points="0,0 0,30 26,15"/></svg>
          </div>
          <div class="player-buffer">
            <div class="spinner">
              <div class="rect1"></div>
              <div class="rect2"></div>
              <div class="rect3"></div>
              <div class="rect4"></div>
              <div class="rect5"></div>
            </div>
          </div>
          <div class="player-video-holder">
            <video width='100%' height='100%' id='video-d49fd4bd1e18e2c75c-html' crossorigin='anonymous' preload="metadata"    style="display:none;"></video>
          </div>
          <div class="player-control-bar hidden">
            <div class="player-play-pause player-button" role='button' aria-label='Play' tabindex='-1' data-tabindex='2' >
              <svg id="play" viewBox="0 0 26 30">
              </svg>
              <svg id="pause" viewBox="0 0 12 20">
                <path d="M1,20h2c0.6,0,1-0.4,1-1V1c0-0.6-0.4-1-1-1H1C0.4,0,0,0.4,0,1v18C0,19.6,0.4,20,1,20z"/>
                <path d="M11,0H9C8.4,0,8,0.4,8,1v18c0,0.6,0.4,1,1,1h2c0.6,0,1-0.4,1-1V1C12,0.4,11.6,0,11,0z"/>
              </svg>
            </div>
            <div class="player-volume player-button" role='button' aria-label='Mute' tabindex='-1' data-tabindex='3'>
              <div class="volume-bar" role='slider' aria-label='Volume slider' aria-valuemin='0' aria-valuemax='100' aria-valuenow='100' aria-valuetext='100% volume' tabindex='-1' data-tabindex='4'>
                <div class="volume-bar-background"></div>
                <div class="volume-track-background"></div>
                <div class="volume-track-controller"></div>
                <div class="volume-track-status"></div>
              </div>
              <svg viewBox="0 0 17.3 13.6">
                 <path id="speaker" d="m7.89999,0.17501l-3.4,3.3l-3.4,0c-0.7,0 -1.1,0.6 -1.1,1.1l0,4.5c0,0.6 0.4,1.1 1.1,1.1l3.4,0l3.5,3.3c0,0 1,0.6 1,-1.2c0,-0.9 0,-4.9 0,-10.9c0,-1.9 -1.1,-1.2 -1.1,-1.2l0,0z"/>
                 <path id="wave-one" d="m10.99999,3.57501c-0.2,0 -0.4,0.2 -0.4,0.4l0,0.8c0,0.2 0.2,0.4 0.4,0.5c0.7,0.2 1.3,0.9 1.3,1.6c0,0.8 -0.5,1.4 -1.3,1.6c-0.2,0.1 -0.4,0.2 -0.4,0.5l0,0.9c0,0.2 0.2,0.4 0.4,0.4c1.7,-0.2 3,-1.6 3,-3.4s-1.3,-3.1 -3,-3.3z"/>
                 <path id="wave-two" d="m10.59999,0.57501l0,0.8c0,0.2 0.2,0.4 0.4,0.4c2.6,0.2 4.6,2.4 4.6,5s-2,4.8 -4.6,5c-0.2,0 -0.4,0.2 -0.4,0.4l0,0.8c0,0.2 0.2,0.4 0.4,0.4c3.5,-0.2 6.3,-3.2 6.3,-6.7s-2.7,-6.3 -6.3,-6.5c-0.2,0 -0.4,0.2 -0.4,0.4z"/>
                 <path id="mute" d="m15.69999,6.87501l1.4,-1.4c0.2,-0.2 0.2,-0.5 0,-0.7l-0.7,-0.7c-0.2,-0.2 -0.5,-0.2 -0.7,0l-1.4,1.4l-1.3,-1.3c-0.2,-0.2 -0.5,-0.2 -0.7,0l-0.7,0.7c-0.2,0.2 -0.2,0.5 0,0.7l1.4,1.3l-1.4,1.4c-0.2,0.2 -0.2,0.5 0,0.7l0.7,0.7c0.2,0.2 0.5,0.2 0.7,0l1.4,-1.4l1.4,1.4c0.2,0.2 0.5,0.2 0.7,0l0.5,-0.8c0.2,-0.2 0.2,-0.5 0,-0.7l-1.3,-1.3z"/>
              </svg>
            </div>
            <div class="player-progress-time">00:00</div>
            <div class="player-tracks" role='slider' aria-label='Seek Slider' aria-valuemin='0' aria-valuemax='0' aria-valuenow='0' aria-valuetext='00:00 of 00:00' tabindex='-1' data-tabindex='4'>
              <div class="player-track-background"></div>
              <div class="player-track-loaded"></div>
              <div class="player-track-controller"></div>
              <div class="player-track-progress"></div>
              <div class="player-track-time">
                <div class="player-track-time-background"></div>
                <div class="player-track-time-gradient"></div>
                <div class="player-track-time-time">00:00</div>
              </div>
            </div>
            <div class="player-total-time">00:00</div>
            <div class="player-share-btn player-button" role='button' aria-label='Sharing' aria-haspopup='true' aria-owns='player-share-sheet' aria-pressed='false' tabindex='-1' data-tabindex='4'>
              <svg viewBox="0 0 478.165 478.165"><path d="M168.752,239.082c0,1.654-0.418,3.088-0.458,4.722l171.223,85.771 c14.803-12.512,33.551-20.342,54.172-20.342c46.681,0,84.436,37.815,84.436,84.456c0.04,46.661-37.735,84.476-84.396,84.476 c-46.681,0-84.237-37.815-84.237-84.476c0-1.534,0.219-3.208,0.458-4.742l-171.342-85.532 c-14.704,12.253-33.511,20.123-54.172,20.123C37.815,323.498,0,285.743,0,239.082s37.815-84.476,84.336-84.476 c20.76,0,39.449,7.87,54.152,20.242L309.93,89.198c-0.259-1.654-0.697-3.228-0.697-4.861C309.492,37.795,347.048,0,393.729,0 c46.661,0,84.436,37.795,84.436,84.316c0,46.641-37.775,84.476-84.436,84.476c-20.681,0-39.369-7.89-54.152-20.282l-171.243,85.691 C168.354,235.835,168.752,237.409,168.752,239.082z"/></svg>
            </div>
            <div class="player-download-btn player-button" role='button' aria-label='Download' aria-haspopup='true' aria-owns='player-download-sheet' aria-pressed='false' tabindex='-1' data-tabindex='13'>
              <svg viewBox="0 0 26 26">
                <path d="m25,17h-2c-0.6,0-1,0.4-1,1v2.5c0,0.3-0.2,0.5-0.5,0.5h-17c-0.3,0-0.5-0.2-0.5-0.5v-2.5c0-0.6-0.4-1-1-1h-2c-0.6,0-1,0.4-1,1v6c0,0.6 0.4,1 1,1h24c0.6,0 1-0.4 1-1v-6c0-0.6-0.4-1-1-1z"/>
                <path d="m12.3,16.7c0.2,0.2 0.5,0.3 0.7,0.3s0.5-0.1 0.7-0.3l6-6c0.2-0.2 0.3-0.4 0.3-0.7s-0.1-0.5-0.3-0.7l-1.4-1.4c-0.2-0.2-0.4-0.3-0.7-0.3-0.3,0-0.5,0.1-0.7,0.3l-1,1c-0.3,0.3-0.9,0.1-0.9-0.4v-6.5c0-0.6-0.4-1-1-1h-2c-0.6,0-1,0.4-1,1v6.6c0,0.4-0.5,0.7-0.9,0.4l-1-1c-0.2-0.2-0.4-0.3-0.7-0.3-0.3,0-0.5,0.1-0.7,0.3l-1.4,1.4c-0.2,0.2-0.3,0.4-0.3,0.7s0.1,0.5 0.3,0.7l6,5.9z"/>
              </svg>
            </div>
            <div class="player-cc player-button" role='button' aria-label='Subtitles/closed captions' aria-expanded='false' tabindex='-1' data-tabindex='19'>
              <svg viewBox="0 0 24 17">
                <path d="M21,0H3C1.3,0,0,1.3,0,3v11c0,1.7,1.3,3,3,3h18c1.7,0,3-1.3,3-3V3C24,1.3,22.7,0,21,0z M10.2,11.9c-0.5,0.2-1,0.3-1.6,0.3
                  c-0.6,0-1.2-0.1-1.7-0.3s-1-0.5-1.3-0.8C5.3,10.7,5,10.3,4.8,9.8C4.6,9.3,4.5,8.7,4.5,8.1c0-0.6,0.1-1.2,0.3-1.7
                  C5,5.9,5.3,5.5,5.6,5.1C6,4.8,6.5,4.5,7,4.3C7.5,4.1,8,4,8.7,4c0.2,0,0.4,0,0.7,0.1c0.2,0,0.5,0.1,0.7,0.2c0.2,0.1,0.5,0.2,0.7,0.4
                  c0.2,0.1,0.4,0.3,0.6,0.5L10,6.2C9.8,6,9.6,5.9,9.3,5.8C9.1,5.7,8.8,5.6,8.5,5.6c-0.3,0-0.6,0.1-0.9,0.2C7.3,5.9,7.1,6.1,6.9,6.3
                  C6.7,6.5,6.5,6.8,6.4,7.1c-0.1,0.3-0.2,0.6-0.2,1c0,0.4,0.1,0.7,0.2,1c0.1,0.3,0.3,0.6,0.5,0.8s0.4,0.4,0.7,0.5
                  c0.3,0.1,0.6,0.2,0.9,0.2c0.4,0,0.7-0.1,0.9-0.2c0.3-0.1,0.5-0.4,0.7-0.6l1.4,1.1C11.1,11.3,10.7,11.7,10.2,11.9z M18.9,11.9
                  c-0.5,0.2-1,0.3-1.6,0.3c-0.6,0-1.2-0.1-1.7-0.3c-0.5-0.2-1-0.5-1.3-0.8c-0.4-0.4-0.7-0.8-0.9-1.3c-0.2-0.5-0.3-1.1-0.3-1.7
                  c0-0.6,0.1-1.2,0.3-1.7c0.2-0.5,0.5-0.9,0.9-1.3c0.4-0.4,0.8-0.6,1.3-0.8C16.1,4.1,16.7,4,17.3,4c0.2,0,0.4,0,0.7,0.1
                  c0.2,0,0.5,0.1,0.7,0.2c0.2,0.1,0.5,0.2,0.7,0.4c0.2,0.1,0.4,0.3,0.6,0.5l-1.3,1.1C18.4,6,18.2,5.9,18,5.8
                  c-0.2-0.1-0.5-0.2-0.9-0.2c-0.3,0-0.6,0.1-0.9,0.2c-0.3,0.1-0.5,0.3-0.7,0.5c-0.2,0.2-0.4,0.5-0.5,0.8c-0.1,0.3-0.2,0.6-0.2,1
                  c0,0.4,0.1,0.7,0.2,1c0.1,0.3,0.3,0.6,0.5,0.8c0.2,0.2,0.4,0.4,0.7,0.5c0.3,0.1,0.6,0.2,0.9,0.2c0.4,0,0.7-0.1,0.9-0.2
                  c0.3-0.1,0.5-0.4,0.7-0.6l1.4,1.1C19.8,11.3,19.4,11.7,18.9,11.9z"/>
              </svg>
            </div>
            <div class="player-settings player-button" role='button' aria-expanded='false' aria-label='Settings' tabindex='-1' data-tabindex='21'>
              <svg viewBox="0 0 15.998 15.998">
                <path style="fill-rule:evenodd;clip-rule:evenodd;" d="M13.998,7c-0.553,0-1.08-0.443-1.291-0.952 c-0.21-0.508-0.15-1.194,0.24-1.585l0.707-0.706c0.391-0.391,0.391-1.024,0.001-1.415c-0.391-0.391-1.024-0.391-1.415,0 c0,0-0.316,0.316-0.707,0.707S10.457,3.5,9.949,3.29C9.442,3.08,8.998,2.553,8.998,2V1c0-0.553-0.447-1-1-1s-1,0.447-1,1v1 c0,0.553-0.442,1.08-0.95,1.291s-1.192,0.15-1.583-0.24L3.756,2.344c-0.391-0.391-1.024-0.39-1.413,0 C1.952,2.734,1.952,3.367,2.342,3.758l0.709,0.708C3.441,4.856,3.51,5.545,3.338,6.062C3.168,6.58,2.648,7.016,2.097,7.01L1,7 C0.448,7,0,7.449,0,8c0,0.553,0.448,1,1,1h1.001c0.552,0,1.087,0.438,1.331,0.925c0.245,0.486,0.188,1.159-0.207,1.546l-0.783,0.77 c-0.391,0.391-0.39,1.025,0,1.414c0.391,0.391,1.024,0.391,1.414,0.001l0.708-0.708c0.391-0.391,1.075-0.451,1.584-0.24 c0.508,0.211,0.95,0.738,0.95,1.291v1.001c0,0.552,0.448,1,1,0.999c0.553,0,1-0.447,1-0.999v-1.001c0-0.553,0.444-1.08,0.951-1.289 c0.508-0.211,1.193-0.15,1.584,0.24l0.707,0.707c0.391,0.391,1.024,0.391,1.413,0c0.391-0.391,0.392-1.024,0.002-1.414l-0.708-0.708 c-0.391-0.391-0.451-1.076-0.24-1.584S13.445,9,13.998,9h1c0.553,0,1-0.447,1-1s-0.447-1-1-1H13.998z M7.998,10 c-1.103,0-2-0.897-2-2s0.897-2,2-2s2,0.897,2,2S9.101,10,7.998,10z"/>
              </svg>
            </div>
            <div class="player-fullscreen player-button" role='button' aria-label='Fullscreen' aria-pressed='false' tabindex='-1' data-tabindex='24'>
              <svg viewBox="0 0 15 15">
                <path d="M4.5,13H2v-2.5C2,10.2,1.8,10,1.5,10h-1C0.2,10,0,10.2,0,10.5V14c0,0.6,0.4,1,1,1h3.5C4.8,15,5,14.8,5,14.5v-1
                  C5,13.2,4.8,13,4.5,13z"/>
                <path d="M4.5,0H1C0.4,0,0,0.4,0,1v3.5C0,4.8,0.2,5,0.5,5h1C1.8,5,2,4.8,2,4.5V2h2.5C4.8,2,5,1.8,5,1.5v-1C5,0.2,4.8,0,4.5,0z"/>
                <path d="M14,0h-3.5C10.2,0,10,0.2,10,0.5v1C10,1.8,10.2,2,10.5,2H13v2.5C13,4.8,13.2,5,13.5,5h1C14.8,5,15,4.8,15,4.5V1
                  C15,0.4,14.6,0,14,0z"/>
                <path d="M14.5,10h-1c-0.3,0-0.5,0.2-0.5,0.5V13h-2.5c-0.3,0-0.5,0.2-0.5,0.5v1c0,0.3,0.2,0.5,0.5,0.5H14c0.6,0,1-0.4,1-1v-3.5
                  C15,10.2,14.8,10,14.5,10z"/>
              </svg>
            </div>
          </div>
          <div class="player-subtitle-cue "></div>
          <div class="player-subtitle-menu player-menu" aria-hidden='true'>
            <div class="player-language player-option">
              <label>Language</label>
              <div class="player-setting">
                <div class="player-select">
                  <select class="player-language-select" tabindex='20' aria-label='Subtitle Language'>
                    <option selected>None</option>
                  </select>
                </div>
              </div>
            </div>
          </div>
          <div class="player-settings-menu player-menu" aria-hidden='true' role='menu'>
            <div class="player-resolution player-option">
              <label>Resolution</label>
                  <select class="player-resolution-select" tabindex='22' aria-label='Video quality'>
                    <option selected>Auto</option>
                  </select>
                </div>
              </div>
            </div>
            <div class="player-speed player-option">
              <label>Speed</label>
                  <select class="player-speed-select" tabindex='23' aria-label='Playback Speed'>
                    <option value="0.25">0.25X</option>
                    <option value="0.5">0.5X</option>
                    <option value="0.75">0.75X</option>
                    <option value="1" selected>1X</option>
                    <option value="1.25">1.25X</option>
                    <option value="1.5">1.5X</option>
                    <option value="2">2X</option>
                  </select>
                </div>
              </div>
            </div>
          </div>
          <div class='player-mobile-muted' role='button' aria-label='Un-mute'>
               <path d="m7.89999,0.17501l-3.4,3.3l-3.4,0c-0.7,0 -1.1,0.6 -1.1,1.1l0,4.5c0,0.6 0.4,1.1 1.1,1.1l3.4,0l3.5,3.3c0,0 1,0.6 1,-1.2c0,-0.9 0,-4.9 0,-10.9c0,-1.9 -1.1,-1.2 -1.1,-1.2l0,0z"/>
               <path d="m15.69999,6.87501l1.4,-1.4c0.2,-0.2 0.2,-0.5 0,-0.7l-0.7,-0.7c-0.2,-0.2 -0.5,-0.2 -0.7,0l-1.4,1.4l-1.3,-1.3c-0.2,-0.2 -0.5,-0.2 -0.7,0l-0.7,0.7c-0.2,0.2 -0.2,0.5 0,0.7l1.4,1.3l-1.4,1.4c-0.2,0.2 -0.2,0.5 0,0.7l0.7,0.7c0.2,0.2 0.5,0.2 0.7,0l1.4,-1.4l1.4,1.4c0.2,0.2 0.5,0.2 0.7,0l0.5,-0.8c0.2,-0.2 0.2,-0.5 0,-0.7l-1.3,-1.3z"/>
            </svg>
          </div>
          <div class="player-stats" aria-hidden='true'>
            <div><div>Video ID:</div><span>d49fd4bd1e18e2c75c</span></div>
            <div><div>User ID:</div><span>d49bdfb51f18eac95a</span></div>
            <div><div>Playback:</div><span class="stat-playback"></span></div>
            <div><div>Dimensions:</div><span class="stat-dimensions"></span></div>
            <div><div>Resolution:</div><span class="stat-resolution"></span></div>
            <div><div>Level Cap:</div><span class="stat-levelcap"></span></div>
            <div><div>Speed:</div><span><span class="sparkline"></span><span class="stat-speed"></span></span></div>
          </div>
          <div class="player-share-sheet player-sheet" aria-hidden='true' role='dialog' aria-live='assertive'>
            <div class="player-card player-social-card">
              <div class="player-card-btn player-card-close" role='button' aria-label='Close overlay' data-tabindex='12' tabindex='-1'>
                <svg viewBox="0 0 8.071 8.07">
                  <path d="M7.924,6.51L5.45,4.035l2.475-2.475c0.196-0.195,0.196-0.512,0-0.707L7.217,0.146 c-0.195-0.195-0.512-0.195-0.707,0L4.036,2.621L1.561,0.146c-0.195-0.195-0.512-0.195-0.707,0L0.147,0.854 c-0.196,0.195-0.196,0.512,0,0.707l2.475,2.475L0.147,6.51c-0.196,0.195-0.196,0.512,0,0.707l0.707,0.707 c0.195,0.195,0.512,0.195,0.707,0l2.475-2.475L6.51,7.924c0.195,0.195,0.512,0.195,0.707,0l0.707-0.707 C8.121,7.021,8.121,6.705,7.924,6.51z"/>
                </svg>
              </div>
              <div class="player-share-options">
                <h2>Share this video</h2>
                <div class="social-sharing">
                  <ul>
                    <li class="facebook" class="facebook" role='button' aria-label='Share on Facebook' data-tabindex='5' tabindex='-1'>
                      <svg viewBox="0 0 16 16">
                        <path style="fill-rule:evenodd;clip-rule:evenodd;" d="M8,0C3.582,0,0,3.582,0,8s3.582,8,8,8s8-3.582,8-8S12.418,0,8,0z M11,5h-1 C9.15,5,9,5,9,7h2v2H9v4H7V9H5V7h2c0-1.531,0-4,3-4h1V5z"/>
                      </svg>
                    </li>
                    <li class="twitter" role='button' aria-label='Share on Twitter' data-tabindex='6' tabindex='-1'>
                        <path style="fill-rule:evenodd;clip-rule:evenodd;" d="M8,0C3.582,0,0,3.582,0,8s3.582,8,8,8c4.418,0,8-3.582,8-8 S12.418,0,8,0z M11.993,5.992c0.004,0.086,0.008,0.174,0.008,0.262c0,2.669-2.03,5.746-5.745,5.746c-1.14,0-2.198-0.336-3.092-0.907 c0.158,0.019,0.326,0.028,0.489,0.028c0.946,0,1.831-0.324,2.522-0.865c-0.884-0.016-1.602-0.6-1.858-1.402 C4.44,8.877,4.622,8.891,4.752,8.891c0.184,0,0.474-0.025,0.644-0.071C4.473,8.633,4,7.817,4,6.84c0-0.009,0-0.018,0-0.027 c0,0.152,0.36,0.243,0.691,0.254c-0.542-0.363-1.122-0.98-1.122-1.682c0-0.369,0.1-0.717,0.273-1.015 c0.996,1.222,2.484,2.026,4.163,2.11C7.97,6.332,7.953,6.178,7.953,6.02C7.953,4.904,8.856,4,9.972,4 c0.581,0,1.105,0.245,1.475,0.639c0.459-0.091,0.892-0.259,1.282-0.49c-0.151,0.472-0.472,0.867-0.888,1.117 c0.408-0.05,0.797-0.158,1.159-0.318C12.729,5.352,12.389,5.707,11.993,5.992z"/>
                      </svg>
                    </li>
                    <li class="pinterest" role='button' aria-label='Share on Pinterest' data-tabindex='7' tabindex='-1'>
                        <path d="M8,0C3.582,0,0,3.582,0,8s3.582,8,8,8s8-3.582,8-8S12.418,0,8,0z M8.668,10.252c-0.626-0.046-0.889-0.349-1.379-0.639 C7.018,10.99,6.688,12.311,5.711,13C5.41,10.919,6.154,9.356,6.5,7.697C5.91,6.732,6.571,4.791,7.814,5.27 C9.344,5.858,6.49,8.855,8.405,9.23c2.001,0.391,2.817-3.375,1.577-4.6C8.189,2.863,4.765,4.59,5.186,7.122 c0.104,0.62,0.761,0.808,0.264,1.661c-1.146-0.247-1.49-1.127-1.445-2.3c0.07-1.919,1.773-3.264,3.481-3.45 c2.161-0.234,4.188,0.771,4.468,2.748C12.268,8.012,10.979,10.427,8.668,10.252z"/>
                      </svg>
                    </li>
                    <li class="linkedin" role='button' aria-label='Share on LinkedIn' data-tabindex='9' tabindex='-1'>
                      <svg viewBox="0 0 486.392 486.392">
                        <path d="M243.196,0C108.891,0,0,108.891,0,243.196s108.891,243.196,243.196,243.196 s243.196-108.891,243.196-243.196C486.392,108.861,377.501,0,243.196,0z M182.397,360.994h-60.799V148.197h60.799V360.994z M153.882,135.156c-15.747,0-28.484-12.768-28.484-28.515s12.768-28.515,28.484-28.515c15.747,0.03,28.515,12.798,28.515,28.515 C182.397,122.388,169.629,135.156,153.882,135.156z M395.193,360.994h-60.799V229.425c0-15.413-4.408-26.204-23.347-26.204 c-31.403,0-37.452,26.204-37.452,26.204v131.569h-60.799V148.197h60.799v20.337c8.694-6.657,30.399-20.307,60.799-20.307 c19.699,0,60.799,11.795,60.799,83.051V360.994z"/>
                      </svg>
                    </li>
                    <li class="email" role='button' aria-label='Share via  Email' data-tabindex='10' tabindex='-1'>
                      <svg viewBox="-304 382 30 30">
                        <path d="M-289,382c-8.3,0-15,6.7-15,15c0,8.3,6.7,15,15,15s15-6.7,15-15C-274,388.7-280.7,382-289,382z M-297,394.7 c0-0.3,0.2-0.4,0.4-0.2l2.5,2c0.2,0.2,0.2,0.5,0,0.6l-2.5,2c-0.2,0.2-0.4,0.1-0.4-0.2V394.7z M-281,402c0,0.4-0.5,1-1,1h-14 c-0.5,0-1-0.6-1-1v-0.3l4.3-3.4c0.2-0.2,0.6-0.2,0.8,0l2.5,2c0.2,0.2,0.6,0.2,0.8,0l2.5-2c0.2-0.2,0.6-0.2,0.8,0l4.3,3.4V402z M-281,399c0,0.3-0.2,0.4-0.4,0.2l-2.5-2c-0.2-0.2-0.2-0.5,0-0.6l2.5-2c0.2-0.2,0.4-0.1,0.4,0.2V399z M-288.6,398 c-0.2,0.2-0.6,0.2-0.8,0l-7.6-6c0-0.4,0.5-1,1-1h14c0.5,0,1,0.6,1,1L-288.6,398z"/>
                      </svg>
                    </li>
                  </ul>
                </div>
                <div class='embed-code-sharing'>
                  <h3>Embed Code</h3>
                  <input class="player-embed-code" spellcheck="false" aria-readonly='true' readonly aria-label='Embed code' data-tabindex='11' tabindex='-1'></input>
                </div>
              </div>
            </div>
          </div>
          <div class="player-download-sheet player-sheet" aria-hidden='true' role='dialog' aria-live='assertive'>
            <div class="player-card-btn player-card-close" role='button' aria-label='Close overlay' data-tabindex='18' tabindex='-1'>
              </svg>
            </div>
            <div class="player-download-options">
              <h2>Download Video</h2>
              <ul>
                <li><a class='sd-download' href="https://sproutvideo.com/videos/d49fd4bd1e18e2c75c/player_download?expires=1581174350&amp;type=sd&amp;uid=62308345-bd2f-4fe5-90ff-00f23d0720f2&amp;signature=sxaziTPOqy54mQqOiTp7Ksx4kCY%3D" target="_blank" arial-label='Download SD video' data-tabindex='14' tabindex='-1'>SD</a></li>
                <li><a class='hd-download' href="false" target="_blank" aria-label='Download HD video' data-tabindex='15' tabindex='-1'>HD</a></li>
                <li><a class='uhd-download' href="false" target="_blank" aria-label='Download UHD video' data-tabindex='16' tabindex='-1'>UHD</a></li>
                <li><a class='source-download' href="false" target="_blank" target="_blank" arial-label='Download source video' data-tabindex='17' tabindex='-1'>Source</a></li>
              </ul>
            </div>
          </div>
        </div>
        <script src="//d1ajyp3swh7ygp.cloudfront.net/jquery.min.js" defer></script>
        <!--[if lte IE 7]>
        <script type="text/javascript" src="//d1ajyp3swh7ygp.cloudfront.net/json2.js"></script>
        <![endif]-->
        <script type="text/javascript">if(typeof Set != 'function'){document.write('<script type="text/javascript" src="https://cdnjs.cloudflare.com/ajax/libs/babel-polyfill/6.26.0/polyfill.min.js" async defer></'+'script>');}</script>
        <script type="text/javascript" src="//d1ajyp3swh7ygp.cloudfront.net/es6.min-f0b305da.js" defer></script>
      </body>
    </html>
    No "mobile" I can see except for "<div class='player-mobile-muted' role='button' aria-label='Un-mute'>". I used ios, android, windows phone, practically all the options.
    Im using linder user agent switcher.
  18. Originally Posted by LZAA View Post
    Tried the demo again. Result same. Doesnt download. This is the allavsoft log.
    [Sat Feb 8 17:06:34 2020] allavsoft 3.22.1.7334 U en_US
    [17:06:34] Parse Page:https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989
    [17:06:34] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:34] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:34] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:34] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:06:35] Page Content Size: 28795...
    [17:06:35] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172603&signature=TJFVaYcpKUYy6c6cODci0Fww%2F3o%3D"
    [17:06:37] Page Content Size: 9...
    [17:06:37] [x] HTTP status: 403
    [17:06:37] [x] Page Title:
    [17:06:37] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:06:37] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:37] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:37] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:37] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:06:38] Page Content Size: 28767...
    [17:06:38] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172606&signature=Enh%2FmwF7O%2BGC0C6V1KSfZIs5GDA%3D"
    [17:06:39] Page Content Size: 9...
    [17:06:39] [x] HTTP status: 403
    [17:06:39] [x] Page Title:
    [17:06:39] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:06:39] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:39] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:39] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:39] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:06:41] Page Content Size: 28771...
    [17:06:41] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172608&signature=zx1jIgKePcLtQNysBYysr7Ni%2FFg%3D"
    [17:06:42] Page Content Size: 9...
    [17:06:42] [x] HTTP status: 403
    [17:06:42] [x] Page Title:
    [17:06:42] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:06:42] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:42] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:42] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:42] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:06:43] Page Content Size: 28769...
    [17:06:43] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172611&signature=SNq6jeuDVhGUAK9fu3Si2ZSYLp0%3D"
    [17:06:44] Page Content Size: 9...
    [17:06:44] [x] HTTP status: 403
    [17:06:45] [x] Page Title:
    [17:06:45] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:06:45] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:45] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:45] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:45] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:06:46] Page Content Size: 28775...
    [17:06:46] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172614&signature=xOmfETQj9wmQoOdMRLAJirTbdhg%3D"
    [17:06:47] Page Content Size: 9...
    [17:06:47] [x] HTTP status: 403
    [17:06:47] [x] Page Title:
    [17:06:47] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:06:47] 1 videodownloaderlib ParseFinished: -1
    [17:06:47] Prevent system to go into sleep mode
    [17:06:47] Report:https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989	-1	0x0	0.00	0	-1	""
    [17:06:47] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:47] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:47] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:47] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:06:49] Page Content Size: 28767...
    [17:06:49] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172616&signature=zRMuWdB5uA%2BWrKX5kBaIdW48rio%3D"
    [17:06:50] Page Content Size: 9...
    [17:06:50] [x] HTTP status: 403
    [17:06:50] [x] Page Title:
    [17:06:50] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:06:50] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:50] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:50] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:50] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:06:51] Page Content Size: 28785...
    [17:06:51] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172619&signature=qogA8Bj3M7lGEuNpmfJIpv3I57g%3D"
    [17:06:52] Page Content Size: 9...
    [17:06:52] [x] HTTP status: 403
    [17:06:52] [x] Page Title:
    [17:06:52] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:06:52] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:52] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:52] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:52] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:06:54] Page Content Size: 28767...
    [17:06:54] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172622&signature=CnvcCcfpMEcReXS6O1w5nw4Ptoo%3D"
    [17:06:55] Page Content Size: 9...
    [17:06:55] [x] HTTP status: 403
    [17:06:55] [x] Page Title:
    [17:06:55] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:06:55] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:55] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:55] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:55] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:06:57] Page Content Size: 28781...
    [17:06:57] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172624&signature=2g7y%2Bg6xUlQklAMv95nOoMw67gQ%3D"
    [17:06:58] Page Content Size: 9...
    [17:06:58] [x] HTTP status: 403
    [17:06:58] [x] Page Title:
    [17:06:58] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:06:58] Parse https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989...
    [17:06:58] "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989" Found parser:sproutvideo
    [17:06:58] userAgent: "Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0"
    [17:06:58] Get page: "https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989"
    [17:07:00] Page Content Size: 28785...
    [17:07:00] Get page: "https://videos.sproutvideo.com/mp?url=https%3A%2F%2Fhls2.videos.sproutvideo.com%2Fa2f584d9e601b00466e8287a4070a02a%2F862f379ddb270f37bf1e30e11cf0a89c%2Fvideo%2Findex.m3u8&expires=1581172627&signature=tN%2Bi5n%2FiGC%2B3sTG7VHfTM3bfrGE%3D"
    [17:07:01] Page Content Size: 9...
    [17:07:01] [x] HTTP status: 403
    [17:07:01] [x] Page Title:
    [17:07:01] Parsed https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989. res: -1
    [17:07:01] 1 videodownloaderlib ParseFinished: -1
    [17:07:01] Prevent system to go into sleep mode
    [17:07:01] Report:https://videos.sproutvideo.com/embed/d49fd4bd1e18e2c75c/1f7cc22d1d2e7989	-1	0x0	0.00	0	-1	""
  19. Member Emeritus
    May 2014
    Hmm. It stopped working the day after post #26. A coincidence?
  20. Originally Posted by ponens View Post
    It is strange but not surprising this thread was probably on their radar
  21. Originally Posted by ponens View Post
    More like after post #22. Divine intervention? lol. Is there any way sprout can be downloaded now?
  22. Member Emeritus
    May 2014
    The mp url was working, at least for the demo, when post #26 was made.
    The non-mp url can still work if the key is downloaded independently and used locally. Not interested in posting explicit instructions.
    Edit: I don't know what you guys are talking about. The mp url is still working, both for the demo and for your porn video. It must just be an allavsoft bug, and not some type of restriction on the mp url in general.
  23. Originally Posted by ponens View Post
    Are you using it on youtube-dl?
  24. Right now mp url is not working: Forbidden.
  25. Using Tubedigger on the two sprout videos mentioned in this thread. Job done with just a few clicks. I chose 1280x720. Zero hassle.
    https://mega.nz/#!pHwllQYL!HDAfOpMBqscN5n3t81fBlNw-eKDMZ0N6izH8G-2pGmI
    https://mega.nz/#!MS41HQrY!ztHRbroCVMsb71nyd7zqOhJkR_h12trKZHG3Z5gsaC4
    Question: why would anybody buy Allavsoft when:
    1) it costs over twice as much
    2) doesn't work for this video download
    3) can only install on up to 2 computers
  26. Question: why would anybody buy Allavsoft when:
    Thats the point of it, Im done buying, so now Im looking for a free option.
    Worked till 06th. As @ponens pointed out, might be a bug. Already sent an email today, awaiting response.
    Need it for one pc - Mine. Not an aggressive downloader, just for the occasional video.
  27. Im looking for a free option.
    You can try the instructions in the following thread (especially post #17) , courtesy of Ponens. I did this several years ago, but it probably still works.
    https://forum.videohelp.com/threads/383521-Question-how-to-download-these-sproutvideos...t=sproutsvideo
    However, the above instructions require an IQ of 97.24 (as verified by IQMaster.com) or higher to be able to follow. I suggest you go to IQMaster.com and take a quick IQ test, and then based on the results, you can try to follow the directions to download the video.
  28. Originally Posted by jimdagys View Post
    Dunno about the IQ bit, but probably helps if you have an idea on web developing(CSS, Javascript, PHP...). However people are saying the method doesn't work. So if it doesn't work, I wont have any way to tell if its my end or sprout pulling the plug.
    I can download from youtube with this and other 'simpler' sites, but certain things I dont understand(read know) about sites such as these ↑↑ as in sometimes,
    -o(overwrite?) is used. Why do we need to use it? It is mandatory?
    If we open the cmd from within the ffmpeg folder, do we still need to type 'ffmpeg' ahead of the url input?
    Is "filename.mp4" at the end an absolute have to?
    Whats the "copy -c:a copy -absf aac_adtstoasc" or "-c copy -bsf:a aac_adtstoasc" thats mentioned at the end at times and sometimes not?
    Sometimes headers are used, sometimes not - why/how is that so?
  29. Member Emeritus
    May 2014
    The user agent shown in the above log ("Mozilla/5.0 (Windows NT 10.0; rv:47.0) Gecko/20100101 Firefox/47.0") will return 403 with a mp url every time.
    The mp url is working with other user agents. Does the allavsoft program have an option to set the user agent?
    Tubedigger is a better program. The tubedigger guy knows what he is doing.
