Hi,
I have an acapella on an LP and an iinstrumental beat on another one. I ripped them by using Audition, now I'd like to mix them with the same programm.
1. how to add the beat under the acapella
2. how to set the pitch/the speed
Thanks!
Work on the clips separately until you combine near the end.
It's not rocket science, but it is science.
Using a timer, work out the bpm of each clip (yes, by counting). Compare them and use one as a reference and one to change. Use math to find the correct ratio to change the changeable clip's tempo making sure to pitch adjust to counteract the change. If you did it correctly, you can now combine, though you will likely have to edit one of those clips to match length.
Can NVENC beat x264+slow preset?
By sophisticles in forum Video ConversionReplies: 10Last Post: 4th Jun 2019, 16:18 -
adobe audition question
By erzane in forum AudioReplies: 4Last Post: 25th Aug 2017, 15:22 -
adobe audition help
By erzane in forum AudioReplies: 5Last Post: 23rd Apr 2017, 18:02 -
Trouble with Adobe Audition
By hellfire45 in forum AudioReplies: 3Last Post: 23rd Feb 2016, 17:35 -
No sound on audition stream
By Anonymous in forum Newbie / General discussionsReplies: 1Last Post: 17th Dec 2015, 06:29
