I have a 700MB Divx AVI file that I want to burn to VCD, but I have to chop it up before I can get it to fit on 2 VCD's (if anyone has any ideas on how I don't have to do this, please let me know). However, when I split my perfectly audio synced original AVI file up, the audio gets out of sync. I've found alot of suggestions for how to correct this problem on this site, but my question is: Do I apply the "fixes" (such as offsetting the audio) before I cut the AVI, or do I apply the "fixes" to the already cut AVI? I would imagine that adjusting the audio in the already cut AVI would result in some lost audio when the files are put back together.
--Cap
If you use this guide it shows you to extract the audio with virtualdub and then shows you how to cut it in tmpgenc.
1st guide under convert
http://www.vcdhelp.com/divxtovcd.htm
I apoligize in advance if this is the guide your already using
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
Need to "chop" my 16:9 avi video down to 4:3
By magic612 in forum Newbie / General discussionsReplies: 15Last Post: 23rd Jan 2011, 05:42 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 10:07 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
