in mkv i found this title "Banshee.S01.1080p.BluRay.DD5.1.x264-DON" how can i edit that? i opened mkv file using mkvtoolnix, but could not find this title.
here is mkvtoolnix header info. but i could not find any option to edit it.Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, RefFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 59 min 34 s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Title : Banshee.S01.1080p.BluRay.DD5.1.x264-DON Writing library : Lavc58.54.100 libx264 Language : English Default : Yes Forced : No
Closed Thread
How to edit mkv file without loosing chapter stops?
By roberta in forum EditingReplies: 14Last Post: 24th Mar 2019, 06:32 -
Edit user data file mkv
By Encrypt in forum MacReplies: 0Last Post: 18th Dec 2018, 07:19 -
Need Help Change Default Title/Global Title to the same one as file name
By Inoyama in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2018, 17:21 -
Change Fonts in Subtitles and Title in mkv File
By RBCC in forum SubtitleReplies: 26Last Post: 19th Apr 2017, 14:25 -
Webm/MKV file crashes on Machete edit-save and makes mess in Avidemux
By gumbygum in forum EditingReplies: 6Last Post: 19th Mar 2017, 15:44
