  1. Anonymous
    Guest
    Oct 2005
    666th portal
    i'd suggest using an audio editor like the free audacity to create a 9 min long audio file. you can just put your 3 min one on the timeline 3 times and then save out the new long version.
  3. Just append the audio in mkvmerge until it's long enough. You can do it in MkvMergeGUI and look at the command line it generates to get an example.
  4. Just append the audio in mkvmerge until it's long enough. You can do it in MkvMergeGUI and look at the command line it generates to get an example.
    Isn't there a risk of glitches at the junctions when proceeding like this ?
