Avyone knows how to change the settings of LG HD (1920x1080p) professional screens in a video wall matrix, in order to get 4K resolution (3840x2160p). The PC's video adapter has 4K support, but doesn't identify the vide wall as a 4K display. The HDMI is connected to the top left monitor (#1) and the computer identify the video wall only as the resolution of that single monitor. The image is distributed fine over the entire surface of the four monitors, but still only at 2K. I really need help with this.
1. You've installed the lg monitor software driver?
2. You're using a high speed 4k class hdmi cable?
3. You're pc software needs updating/settings adjustment -
you're missing a piece of hardware. i believe you need a dedicated video wall processor. i.e. - https://www.amazon.com/dp/B07L51VMV9/ref=psdc_172546_t1_B07YY6GWYK or enough video cards to have separate hdmi/dvi-d outputs for cables to each screen.
4x2 video wall - ffmpeg / vlc playback
By lootssl in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2018, 19:00 -
Video wall display keeps crashing
By JVRaines in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jun 2018, 08:53 -
2x2 4K VIDEO Wall
By WonderPonklay in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2017, 19:45 -
Resolution Question: 4 x 1080p monitors = 4K 2x2 Video Wall?
By GamerHaHa in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2016, 02:35 -
Converting a sample video file of any resolution to 13000x1080 resolution
By user321 in forum Video ConversionReplies: 6Last Post: 6th Jul 2015, 07:21
