I tried to register at the Shark007 site, but they block NordVPN users.
I installed Icaros 3.1. I also run Shellfolderfix on Windows 10 x64 1809 (17763). The CPU is a I9-10940X on an MSI X299 Creator motherboard with 32GB DDR4-3600 CL16 RAM.
Once installed Shellfolderfix starts behaving erratically. It randomly doesn't save window positions, or forgets existing ones.
When I right click a 4K file that is stored on optical media Explorer completely crashes, requiring a restart.
Uninstall Icaros and all is well. I guess I shouldn't be surprised - they are both shell extensions, and Shellfolderfix has been around for a very long time. There are probably not many people using it.
I am using Icaros because I want some way to show 4K and AVI thumbnails, which Windows doesn't seem to like for some reason.
Is there a work around, another utility that will show the thumbnails or some other way to achieve the desired result?
thanks
Results 1 to 1 of 1
10940x with Creator X299 Motherboard, 32GB DRR4-3733, RTX 3080 Ti GPU
Does anyone know if Icaros can view thumbnails for Canon 5D Mark IV files?
By Darkmatter in forum Newbie / General discussionsReplies: 4Last Post: 25th Nov 2018, 23:29 -
Question regarding software you have on your site. (Icaros)
By Darkmatter in forum Newbie / General discussionsReplies: 0Last Post: 20th Sep 2018, 15:17 -
Icaros: Reset Property Filetypes
By Alexus in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2017, 13:53 -
Rtmp Explorer not supported
By blanc in forum Video Streaming DownloadingReplies: 4Last Post: 18th Jul 2017, 09:33 -
Bug with Icaros and Windows 10 1607
By Grinchy in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2017, 15:00
