I used to use idman to download online videos ,but after this update idman doesn't detect the videos,nor using Inspect feature of chrome
any solution beside live capture ?
thank you
Results 1 to 29 of 29
Streamlink work for this site using powered by JW Player 8.4.2
Code
Code:streamlink --http-header "Origin=xxxxxxxx" "m3u8url"
Still waitting download.................C:\Users\xxxxxxxxx>streamlink --http-header "Origin=xxxxxxxxxxxxxxxxxxxxxxxxxx" "https:
//jlexfla0y.nan-hayse.xyz/v1/7qvYDxXvVAFiezhlO3p5OzhPozXTnzx5D8bbOJFTWyKpLSCKLS m
yLUIK/0/playlist.m3u8" best -o "D:/test.ts"
[cli][info] Found matching plugin hls for URL https://jlexfla0y.nan-hayse.xyz/v1
/7qvYDxXvVAFiezhlO3p5OzhPozXTnzx5D8bbOJFTWyKpLSCKLS myLUIK/0/playlist.m3u8
[cli][info] Available streams: 720p (worst, best)
[cli][info] Opening stream: 720p (hls)
[download][test.ts] Written 40.3 MB (1m2s @ 598.3 KB/s) [
cli][info] Stream ended
Interrupted! Exiting...
[cli][info] Closing currently open stream... -
No need for play the video, i'm get m3u8 url for download with streamlink
mmm... very strange. i have latest stream detector on my latest ffox but this don't finds m3u8....
which version of ffox and stream detect you have??
[Attachment 51758 - Click to enlarge] -
see this post at #17 for help
https://forum.videohelp.com/threads/395363-Very-hard-obtain-valid-string-to-download-with-youtube-dl -
sorry im a newbie ,how to use streamlink and which extension should i use to download the video
do you only need this video? >> https://openloadmovies.ac/movies/harriet-2019/ or do you want to download more? if you only need that video maybe someone can download it for you as its not realy easy for newbies to download with streamlink or someone needs to explain it instead of pointing
thank you for your help ,about streamlink i will manage to use it ,do I need any other extension...because i see in post 8 an extension but i don't know what it's called
You need https://www.videohelp.com/software/Streamlink >> https://addons.mozilla.org/nl/firefox/addon/uaswitcher/? >> https://addons.mozilla.org/nl/firefox/addon/video-downloadhelper/? and >> https://addons.mozilla.org/nl/firefox/addon/hls-stream-detector/? in total you need 3 extensions use them on Firefox when you have installed them set uaswitcher to Mobile Android Phone / Firefox 72 and set streamdetector to streamlink and just copy the link and paste it in streamlink look image below
thank you bro for your time and help ,I will follow your instructions ,i appreciate it
ok i did all but i'm stuck on how to copy link to streamlink ,should I launch cmd in streamlink folder and just paste the link detected by stream detector
because I did it and i get streamlink: error: unrecognized arguments: -
Try this in cmd >>> streamlink --http-header "Origin=xxxxxxxxxxxxxxxxxxxxxxxxxx" "https:
yLUIK/0/playlist.m3u8" best -o "D:/test.ts" or this >> streamlink --http-header "User-Agent=Mozilla/5.0 (Android 10; Mobile; rv:72.0) Gecko/72.0 Firefox/72.0" --http-header "Referer=https://openloadmovies.ac/hydrax.html?key=61d9d5c2802c3910bde21cf1e5d6531b&t ype=md5&slug=f0a5186bbbfb2095879d28511a9ea798" -o "playlist.ts" "https://0tk8cgtdn.joseph-mancha.xyz/v1/7qvYDxXvVAFiezhlO3p5OzhPozXTnzx5D8bbOJFTWyKpLSCK6S eK6aIK/0/playlist.m3u8" best -
Otherwise if it does not work wait for others to reply as i dont use streamlink since it doesn't realy support many website's like youtube-dl
I was able to use Tubedigger ($15) to download the video. If you want, I can download it later and post the download on mega. I'm at public library and don't have time now.
640X270I was able to use Tubedigger ($15) to download the video.
https://mega.nz/#!0foFwKDJ!1gN6QSxU9DQJgsi1gGfI9cvacyKSj-DY5XTJ9vrozTI
Downloading videos with player.pl
By robza171 in forum Video Streaming DownloadingReplies: 8Last Post: 18th Mar 2019, 12:36 -
downloading videos from TVNZ
By candyman1983 in forum Video Streaming DownloadingReplies: 8Last Post: 24th Dec 2018, 18:00 -
Downloading Videos From Twitter
By devilcoelhodog in forum Video Streaming DownloadingReplies: 4Last Post: 5th Feb 2018, 16:48 -
Downloading youtube videos with VLC Media Player, quick question
By MISS CHIEVOUS in forum Video Streaming DownloadingReplies: 3Last Post: 15th Apr 2017, 17:28 -
Downloading videos from NRK TV
By Seiji Tanaka in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2016, 08:44
