I rendered for 2 hours a 17 minute video, when i came back back home i saw this error message. What is strange: the file seems to have rendered normally.. cant spot anything wrong. Yet, im still paranoid and considering rendering again... what could have triggered this error? Never seen this before and im working my same 1080p template i've been using for years. In fact I did render this same project the other day and didn't trigger any errors.
Results 1 to 12 of 12
you never know. it could have been a ram error or there might have been a hard drive write error.
Anything in the Event Viewer perhaps ? (If there's a warning as vague as "the reason for the error could not be determined" it won't be helpful... é_è)
This is a Vegas-specific problem with MP4 files. I assume you were using the Sony h.264 encoder and not the Mainconcept. I have seen that message many times when I choose any frame rate other than one of the defaults. Did you choose a frame rate other than 23.976, 24, 25, 29.97 or 59.94? If so, that is probably the problem. The Sony encoder also throws this error message with other "non-standard" settings, including really high bitrates.
Vegas Pro 13 is as far as I went, so I do know it pretty well. I still use versions 7, 8, 10, & 11. None of them does a very good job with h.264, so long ago I started frameserving into MeGUI. It provides much better results, IMHO. -
Im using this presset:
like I said never had a problem before, I will try rendering again, maybe it was a random io error.Use this setting to create an MP4 (AVC/AAC) file for progressive internet downloads.
Audio: 192 Kbps; 44.100 Hz; 16 Bit; Stereo; AAC
Video: 29,970 fps; 1920x1080 Progressive; YUV; 20 Mbps
Pixel Aspect Ratio: 1,000 -
I render it again, and the error happened. I have the window opened now, can someone tell me where to look the event error log?
Any ideas? I dont know why this happening. Maybe because I have little space left? should I try rendering again with more space? when im finished there is only 800 megs free.
yes that is a possibility. you need at least as much space in vegas's temp folder as the final video. if you can add another drive i'd try again with plenty of drive space to spare.--
Rendered video brightness issue (Vegas)
By Welsh Jester in forum EditingReplies: 2Last Post: 6th Mar 2019, 06:10 -
Suggestions to avoid glitched frames in rendered video from Sony Vegas?
By enzeru in forum EditingReplies: 5Last Post: 5th Jul 2017, 08:52 -
Sony Vegas - Strange problem with Sony AVC/MVC rendered files
By RMCF10 in forum Newbie / General discussionsReplies: 16Last Post: 5th Feb 2016, 04:04 -
Sony Movie Studio 13 - Black Preview Screen and Rendered Video
By kapparomeo in forum EditingReplies: 5Last Post: 15th Jul 2015, 21:29 -
[Vegas Movie Studio] The Preview is OK, but the Rendered Video isn't
By Brach_Movic in forum EditingReplies: 4Last Post: 11th Feb 2015, 17:25
