What is a good program to join mp3 files. I have an audiobook which has a couple hundred and do not want to have to click start a new one very few minutes. Audacity is fine for a couple but too much hassle for lot. Anyone used http://www.dvdvideomedia.com/mp3cutter.html
Freeware and reliable mp3DirectCut has such option under File > Batch processing
I've been using Shuangs Audio Joiner for about 5 years and have never had a problem with it. Very easy to use. I just checked and it's still available.
I don't know about now but when I got it about 5 years ago it was free of ads and spyware, but I also see that it's still the same version, so seeing as it hasn't been updated my guess would be that it's still safe.
http://www.dvdvideomedia.com/mp3cutter.html is easy to use.They say it is clean. It tries to connect to http://165.193.78.234/ on install but that is easy to block with fw
What is a good program for losslessly joining mp3 files without re-encoding
By imkira3 in forum EditingReplies: 4Last Post: 25th Jun 2019, 23:06 -
Joining files
By ForumID in forum EditingReplies: 1Last Post: 1st Jun 2018, 19:05 -
Joining Multiple MP3 (Audios) together. SOFTWARE? Mp3DirectCut?
By UmmAddan in forum AudioReplies: 14Last Post: 1st Oct 2015, 08:26 -
Joining 2 matroska files
By boristhecat in forum EditingReplies: 1Last Post: 5th Jul 2015, 18:37 -
Joining two video files
By gracemichelle in forum EditingReplies: 6Last Post: 9th May 2015, 08:56
But how do i get rid of the files when they are processed? They are still there if i close and reopen the program.Even a new instance of the program. Have to open new files to replace them
