Hello,
Any help would be greatly appreciated with this issue i've been having with handbrake.
Source:
- DVD (with multiple 20-40 titles)
- subtitles are VOBSUB and CC608
Desire:
- export them as mkv (smallest file size without losing any visible quality) with the embedded subtitles
Configuration Steps
- i've loaded the video VIDEO_TS
- all the titles load
- using Fast 1080p30 preset
changes to the preset
- summary > format > MKV File
- Video > Video Encoder > H.265 10-bit
- Subtitles > tracks > Add all tracks
> Foreign Audio Search <x> Forced only
> 0: English Closed Caption (4:3) [VOBSUB]
> 1: English Closed Caption [CC608]
Issue1: Bulk titles, added to queue do not retain all subtitle tracks from the settings changed above.
- If I do one title with the above settings and add it then it works as desired in the summary window of the queue interface
Subtitles: Foreign Audio Search, Forced Only
1: English, Closed Caption [CC608]
BUT if i add all the titles (File > Add titles to Queue) then it seems to use the original unmodified preset.
Subtitles: Foreign Audio Search, Forced Only, Burned In
<missing 0:...>
<missing 1:...>
Issue2: Creating a new preset with Configuration steps does not retain the settings
- so once the above is setup then you click Subtitles > Save New Preset
- add:
Preset Name: test1
Category: <default: My Presets>
Dimensions: <default: source maxium>
Audio: <default unchanged>
Subtitles:
Options:
[x] Add Closed captions when available
[x] Add Foreign Audio Search
Burn-in Behavior: None
[x] DVD Subtitles
[x] Blu-ray Subtitles
so once you click "add"
- it removes the 0: English Closed Caption (4:3) [VOBSUB]
- enables the [x] Burn in for foreign Audio Search.
So essentially it's a partial reset of the presets and doesn't save the Subtitle options.
Question:
How do you retain the above presets in "Add titles to queue" without repeating the step-by-step configuration for each title?
thanks
FYI - i've used MakeMKV it has everything (subtitles) but the file size is 3 times bigger.
Results 1 to 1 of 1
Handbrake: Same audio settings for all the titles when converting a batch?
By Srivas in forum Video ConversionReplies: 3Last Post: 27th Oct 2018, 16:40 -
batch cropping with handbrake
By RBCC in forum EditingReplies: 0Last Post: 20th May 2018, 22:13 -
Batch Cropping in handbrake?
By RBCC in forum EditingReplies: 3Last Post: 15th Mar 2018, 18:52 -
Handbrake batch nobs
By RBCC in forum EditingReplies: 3Last Post: 19th Dec 2017, 06:20 -
Batch with Handbrake
By BobAchgill in forum Newbie / General discussionsReplies: 6Last Post: 7th Jun 2016, 00:14
