  1. Recently came across pyIDM. Did forum search but got nothing.
    Here is the info from https://github.com/pyIDM/pyIDM "python open source alternative to IDM (Internet Download Manager) with multi-connections, high speed engine, based on python, pycurl, youtube_dl, and pysimplegui" version listed is 3.6.10
    Features:
    High download speeds "based on cuRL"
    Multi-connection downloading
    Scan and resume uncompleted downloads.
    Support for Youtube, and a lot of stream websites "using youtube-dl to fetch data".
    Auto check for application updates.
    Scheduling downloads
    Re-using existing connection to remote server.
    Clipboard Monitor.
    Refresh expired urls.
    Simple GUI interface with 140 themes available.
    user can control a lot of options:
    selecting Segment size.
    Speed limit.
    Max. Concurrent downloads.
    Max. connections per download.
    Any comments?
  2. more complicated.... use simply IDM
  3. Is this simple enough?
