https://play.boomstream.com/BxO4Pmau
it is the url of video.
Results 1 to 11 of 11
Well, what did you do expect? It is a good software that does exactly what you ask for. Why not pay for it if you like it. I showed you that I was able to play the downloaded video in VLC. Here is a video: https://streamable.com/e3d0u
Obviously you don't necessarily need to use that software. It does not do anything special. It just saves you a few clicks and downloads the video immediately. It is no magic.
Here is the output file log:
Code:General Complete name : C:\Users\Videos\TubeDigger\стерва 2 блок .mov - Boomstream - 1920x1080 4196K.ts Format : MPEG-TS Format profile : No PAT/PMT File size : 1.01 GiB Duration : 33 min 24 s Overall bit rate mode : Variable Overall bit rate : 4 320 kb/s Video ID : 258 (0x102) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Format settings, GOP : M=4, N=50 Duration : 33 min 24 s Nominal bit rate : 4 000 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : x264 core 152 r19 ba24899 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=50 / keyint_min=5 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=8000 / vbv_bufsize=16000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Audio ID : 259 (0x103) Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Format version : Version 4 Muxing mode : ADTS Codec ID : 2 Duration : 33 min 24 s Bit rate mode : Variable Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : -67 ms
Somebody who is very experienced probably could use free software to download the video. Maybe they will post how to do it. Otherwise, I use Tubedigger ($15).DRM protected. very hard[???]
Mega link to video (1280x720):
https://mega.nz/#!xC4mEIZY!cTwF_-YFVbO0ff--vpmombNlLJqiSTqjWl4Xpk0IqZA -
Tudigger it doesn't always work, on any video... maybe yes in this specific case....
but I doubt there are other easy ways to download a DRM protected video.
let's see if someone good guys writes us a tip here!
more video files listed in Video-Download-Helper-Addon in Firefox
By blanc in forum Video Streaming DownloadingReplies: 0Last Post: 20th Mar 2018, 09:38 -
Download a video from video sharing site
By achy635 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Sep 2017, 12:07 -
How download video from here?
By overburner in forum Video Streaming DownloadingReplies: 2Last Post: 15th Dec 2016, 11:45 -
fazer download de um video smil ? How do the downoad as this video?
By gabil123 in forum Video Streaming DownloadingReplies: 0Last Post: 6th Sep 2016, 00:16 -
how to download video from this website http://video.tv.ae/movies/4127
By bichicha in forum Video Streaming DownloadingReplies: 3Last Post: 2nd Jul 2016, 10:52
