Anyone know where I can find an Extron IR901 remote? IR903's are seemingly available everywhere but I need an IR901. None on eBay and none of the many IN1502's on there have remotes with them.
Or how can I remote control an IN1502 via its serial port from Windows?
I picked up a IN1502 and an AverKey3 Plus (with remote) super cheap. I'm going see how it goes running S-Video from an AG1980 to the IN1502 to scale to 800x600 then put that into the AverKey3 to capture S-video.
Hopefully the Extron scaler will clean up / stabilize the video to give the AverKey3 a clean signal.
why? the in1502 in strictly a scaler. no line or frame tbc.
The scaler shouldn't pass through any copy protection signals, real or improperly detected on home recorded tapes.
The in1502 is quite antiquated now, and not very versatile for CE devices, but whatever.
Look at chapter 3 of the user manual. It says pretty plainly how to format SIS ascii commands and communicate via an rs232 serial port. If you need some verification assistance in testing them out, also DL a copy of DataViewer.
Or just run PCS when you need to make a change, since it should work with that model and has a decent gui for it (I would assume).
<edit>nm, it appears they dropped pcs support of that model a while ago</edit>
ScottLast edited by Cornucopia; 28th Jan 2020 at 00:12.
What's PCS and what's the newest version with support for the IN1502?
PCS=Product Configuration Software.
Current version is 4.5.1. Oldest version I see listed in their archives is v1.3.x
Not sure when it was dropped.
...upon further reading, it looks like it pre-dates PCS (IN1502=c.2005, vs PCS=c.2012/2013), so likely was never supported.
Remote control fyi
By majormulatto in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Jun 2017, 20:05 -
Panasonic HC-X920 and remote controll
By Stile in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 14th May 2016, 18:12 -
How to control VLC with Hauppauge ir remote
By colt4523 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2016, 20:46 -
VLC socket (Remote Control)
By LuukS in forum MacReplies: 1Last Post: 28th Aug 2015, 15:43 -
VD Remote or VA Cast
By clayto in forum ComputerReplies: 0Last Post: 27th May 2015, 17:11
