Hi, I'm used with DVD Decrypter to RIP my DVDs, then I keep the files on .VOB.
I'd like to cut and split those files, so actually I use Mpg2Cut2 but this one is not precise enough. I'd like a more frame precision tool, and free.
Thanks!!
Results 1 to 9 of 9
I've used VideoRedo in the past. There's also TMPGEnc MPEG Smart Renderer (maybe some of the other products) and SolveigMM Video Splitter.
Ok, thanks. And what about Virtual Dub, is it less accurate (maybe obsolete?) than the ones you listed?
VirtualDub is frame accurate but it will have to reencode the entire video if the input is VOB. If you don't mind reencoding (and losing quality) you can use any editor that can read VOB files.
With high compression codecs like MPEG2 the problem is that most frames only contain the changes from prior frames. They start with a keyframe -- a frame encoded much like a JPEG image. The second frame only includes changes from the keyframe. The third frame only includes changes from the second frame. Etc. Until (about 15 frames later with DVD MPEG2) another keyframe is encoded. (It's actually more complex than that but that's the general idea.) The keyframe and all the frames that depend on it are called a GOP (Group Of Pictures). If you trim away the keyframe the rest of the GOP can no longer be reconstructed. So editors that don't reencode can only cut on keyframes. Smarter editors allow you to cut on any frame but must reencode the cut GOPs. So only a few frames at the cuts lose quality. Other editors will let you cut on any frame but will reencode the entire video. -
For such purpose I've used DVBCut and Avidemux, both were accurate enough for my needs (15 frames is about half a second). DVBCut seemingly allows to cut with a 1 frame accuracy, but I'm not sure if it reencodes when the cutting point is not a key frame (which is called “smart rendering”, and which would be surprising considering that it's free and small), or if the cut is actually made on the next key frame and thus less accurate than it appears to be.
The description of the program here says:
the input video and audio data is mostly kept unchanged, and only very few frames at the beginning and/or end of the selected range are re-encoded in order to obtain a valid MPEG file.
VSDC cutting/splitting slowed down video
By bigchief247 in forum Newbie / General discussionsReplies: 2Last Post: 9th Apr 2019, 23:38 -
Cutting/Splitting video in specific parts with avisynth?
By killerteengohan in forum RestorationReplies: 34Last Post: 2nd Mar 2017, 18:18 -
cutting vob & m2ts
By erzane in forum EditingReplies: 13Last Post: 25th Sep 2015, 03:45 -
VOB DTS to VOB AC3 5.1 in ffmpeg not working!!
By mithravishnu in forum AudioReplies: 6Last Post: 10th Jun 2015, 09:55 -
Splitting DVD [VOB] into 4 min clips
By rodhudson in forum EditingReplies: 4Last Post: 13th May 2015, 11:26
