Hi, I have a cable which was in cable set together with Samsung Smart TV.
I can use it to connect VHS player with Samsung TV.
I am wondering if I can plug this mini-jack to my Laptop and receive video as Samsung TV does. Then do something with this captured video.
Or do you see any other option on how to digitize this signal which I have already on Samsung TV?
Thanks in advance for advices!
No.
All the cable does is combine the video and audio into a single plug. No conversion is done. To get your VCR signal into a form (digital) your laptop can accept requires a video capture card.
Start by reading this link on how to PROPERLY (for those who'll jump in with their, But there's an easier and cheaper way suggestions) do a video capture. http://www.digitalfaq.com/editorials/digital-video/professional-analog-workflow.htm The only real difference is that in home video capture setup, a single VCR and a single capture device MAY be enough to do a decent/good job.
Then read this to see if your VCR is on the short list of recommended VCRs. http://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide.html
And if you're interested and willing to spend the money for a known/proven good setup, check this post and contact lordsmurf for what you want/need: http://www.digitalfaq.com/forum/marketplace/8057-sale-complete-workflow.html
Keep in mind that you can recoup a good portion of your investment after you're done by reselling your equipment.
If you just have a few tapes to transfer you may consider letting lordsmurf do the work: http://www.digitalfaq.com/services/video-conversion-tape-to-dvd.htm
Why, lordsmurf, lordsmurf, lordsmurf? It's because he's one of the couple of handful of truly knowledgeable, honest and trustworthy members on VH and digitalfaq.com (which he's either a top administrator or possibly owner/creator of).
To be perfectly clear. I have absolutely no association with lordsmurf other than having the utmost respect for his knowledge and willingness to help others get the best out of their videos. As I stated above. Others may come in with cheaper and easier suggestions, but good/very good and cheap/easy are mutually exclusive. -
Your TV is the one digitizing the video signal not the cable, That cable does nothing it is as dumb as a second coat of paint.
How to Play Mini DV Tapes on new TVs w/o RCA hookups
By doug1022 in forum Newbie / General discussionsReplies: 4Last Post: 13th May 2019, 18:35 -
difference between using a s-vhs scart socket contra a s-vhs s-video jack
By Desve in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2019, 10:59 -
connect Bluetooth to Samsung SCL860
By liefhidebound in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Aug 2015, 09:19 -
Problem with HDMI to RCA converter
By alien91 in forum Video ConversionReplies: 6Last Post: 6th Aug 2015, 13:22 -
Canon mini hot shoe to jack adapter or DM-100 alternative?
By Bencuri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Aug 2015, 13:47
