Hello
We are using Imprex P/N CLPCIe03 frame grabber and streampix software to capture 120FPS video
Now we are looking for another software to capture 30FPS video from the Imprex P/N CLPCIe03 frame grabber board
Does anyone know such software?
https://4kpornindex.com/
I suspect that if the software included with the Imprex P/N CLPCIe03 frame grabber can't do what you want, then you will need to find someone to write custom software for it using the SDK provided with the device.
The capture software that is known to me and most other members of this forum supports typical consumer video connections and possibly SDI. I doubt that there are more than a handful of people here who know anything about the kinds of video connections that your frame grabber has let alone alternatives to streampix that will work with it.Last edited by usually_quiet; 24th Jan 2020 at 10:31.
DVD Authoring Software advice
By 3-Phase in forum Authoring (DVD)Replies: 8Last Post: 20th Nov 2019, 18:41 -
Newbie software advice - cut/combine clips with image stabilisation
By Hyrax in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2019, 17:28 -
Can some one pls advice me best free software thank you
By Muymuy in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2018, 05:52 -
Equipment and Software Advice Mac
By benchurch in forum MacReplies: 4Last Post: 1st Dec 2015, 18:31 -
Need software advice
By mightyxu in forum EditingReplies: 2Last Post: 29th Nov 2015, 18:02
