  1. Member koberulz's Avatar
    Oct 2006
    Australia
    I have a Premiere sequence. 1280x720, 29.97fps.
    I output it as an ac3 file for audio, and an AVI file for video. The AVI plays fine.
    I brought it into MeGUI and created a .264 file. It plays back in slow motion when using PowerDVD.
    I muxed it with the audio in MKVToolnixGUI. It plays back at fast speed, and the video runs out long before the audio does.
    I muxed it again with MKVToolnixGUI, this time manually setting the frame rate. This plays back fine on my PC but when I load it onto my Emby server and play it back on my LG TV, the playback speed is all over the place. Audio is fine, but the video just randomly speeds up and slows down.
    AVI file:
    General
    Complete name                            : L:\zzvideo.avi
    Format                                   : AVI
    Format/Info                              : Audio Video Interleave
    Format profile                           : OpenDML
    File size                                : 137 GiB
    Duration                                 : 2 h 39 min
    Overall bit rate                         : 123 Mb/s
    Recorded date                            : 2020-01-23T12:22:13+08:00
    Video
    Format                                   : YUV
    Codec ID                                 : ULH2
    Codec ID/Info                            : Ut Video Lossless Codec
    Codec ID/Hint                            : Ut Video
    Bit rate                                 : 123 Mb/s
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate                               : 29.970 (30000/1001) FPS
    Chroma subsampling                       : 4:2:2
    Compression mode                         : Lossless
    Bits/(Pixel*Frame)                       : 4.439
    Time code of first frame                 : 00:00:00:00 / 00:00:00:00
    Time code source                         : Adobe tc_A / Adobe tc_O
    Stream size                              : 137 GiB (100%)
    .264 file:
    General
    Complete name                            : L:\zzmegui.264
    File size                                : 4.92 GiB
    Writing library                          : x264 core 157 r2969 d4099dd
    Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=1 / keyint=30 / keyint_min=1 / scenecut=0 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=23 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0
    Video
    Format profile                           : High@L4.1
    Format settings, ReFrames                : 4 frames
    Frame mode                               : Frame doubling
    Height                                   : 720 pixels
    Color range                              : Limited
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    AC3 file:
    General
    Complete name                            : L:\zzaudio.ac3
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    File size                                : 256 MiB
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 224 kb/s
    Audio
    Format                                   : AC-3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Bit rate mode                            : Constant
    Bit rate                                 : 224 kb/s
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 31.250 FPS (1536 spf)
    Bit depth                                : 16 bits
    Stream size                              : 256 MiB (100%)
    MKV file that plays back too fast (video ends at approximately 1h 20m):
    General
    Complete name                            : L:\zzmuxed.mkv
    Format                                   : Matroska
    Format version                           : Version 4 / Version 2
    File size                                : 5.17 GiB
    Overall bit rate                         : 4 627 kb/s
    Encoded date                             : UTC 2020-01-24 06:57:03
    Writing application                      : mkvmerge v40.0.0 ('Old Town Road + Pony') 64-bit
    Writing library                          : libebml v1.3.9 + libmatroska v1.5.2
    Video
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 1 h 19 min
    Bit rate                                 : 8 802 kb/s
    Height                                   : 720 pixels
    Frame rate mode                          : Variable
    Frame rate                               : 59.940 (60000/1001) FPS
    Original frame rate                      : 29.970 (30000/1001) FPS
    Bits/(Pixel*Frame)                       : 0.159
    Stream size                              : 4.92 GiB (95%)
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : AC-3
    Codec ID                                 : A_AC3
    Bit rate                                 : 224 kb/s
    Bit depth                                : 16 bits
    Stream size                              : 256 MiB (5%)
    Title                                    : Dolby Digital 2.0
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Menu
    00:00:00.000                             : en:Chapter 1
    00:09:08.715                             : en:Chapter 2
    00:24:45.751                             : en:Chapter 3
    00:26:10.202                             : en:Chapter 4
    00:39:58.463                             : en:Chapter 5
    00:59:22.659                             : :Chapter 6
    01:01:21.444                             : :Chapter 7
    01:02:51.868                             : en:Chapter 8
    01:11:16.305                             : en:Chapter 9
    01:23:49.558                             : en:Chapter 10
    01:25:53.115                             : en:Chapter 11
    01:28:43.451                             : en:Chapter 12
    01:49:56.957                             : en:Chapter 13
    01:52:01.682                             : en:Chapter 14
    01:53:52.793                             : :Chapter 15
    02:29:04.235                             : en:Chapter 16
    02:33:32.937                             : en:Chapter 17
    MKV file that plays back correctly on PC but is all over the place on LG:
    General
    Format                                   : Matroska
    Encoded date                             : UTC 2020-01-23 17:15:35
    Video
    Bit rate                                 : 4 401 kb/s
    Height                                   : 720 pixels
    Frame rate mode                          : Constant
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : AC-3
    Codec ID                                 : A_AC3
    Bit rate                                 : 224 kb/s
    Bit depth                                : 16 bits
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Menu
  2. Originally Posted by koberulz View Post
    It seems you (MeGUI) set --pulldown double when encoding using x264. Don't do that if you target mkv to avoid such troubles.
  3. Member koberulz's Avatar
    Oct 2006
    Australia
    WTF? It's set to "none" in the MeGUI config and isn't mentioned in the command line thing at the bottom of that window either.
  4. My guess is you selected "Target Playback Device:" "Blu-Ray" and MeGUI auto-inserts --pulldown double because 720p29.97 is not Blu-Ray compatible while 720p59.94 is. MeGUI's log should show the actual full command-line used.
    tl;dr: Don't select Blu-Ray as target device if you are creating mkvs.
  5. Member koberulz's Avatar
    Oct 2006
    Australia
    ....good point. Forgot to check that.
