I created an MKV file and put it on my Emby server. Sat down to watch it. Missed something, tried to use the 'skip back' function to go back ten seconds. Nothing happened. I tried the 'skip forward' button. Also no response. Chapter skipping doesn't work either. I backed out, and then went back into it via the 'resume' button...and it started from the beginning.
Using MKVToolnixGUI's Info Tool, I see 'Seek head' listed all the way down the end of the list, after all the clusters. There's a 'Seek head' entry at the start as well, but it only has one Seek Entry. The one at the end has five.
What's going on here?
Video came out of Premiere Pro as a lossless AVI file and an ac3 file. AVI into MeGUI to create a .264 file, mux with MKVToolnix, add chapters with MKVToolnix.
MediaInfo:
Code:General Format : Matroska Format version : Version 4 / Version 2 File size : 10.6 GiB Duration : 3 h 16 min Overall bit rate : 7 743 kb/s Encoded date : UTC 2020-01-21 13:56:07 Writing application : mkvmerge v40.0.0 ('Old Town Road + Pony') 64-bit Writing library : libebml v1.3.9 + libmatroska v1.5.2 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 3 h 16 min Bit rate : 7 397 kb/s Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Scan type, store method : Interleaved fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.714 Stream size : 10.1 GiB (96%) Writing library : x264 core 157 r2969 d4099dd Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=0 / keyint=30 / keyint_min=1 / scenecut=0 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=23 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0 Default : Yes Forced : No Color range : Limited Color primaries : BT.601 NTSC Transfer characteristics : BT.601 Matrix coefficients : BT.601 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 3 h 16 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Stream size : 269 MiB (2%) Title : Dolby Digital 2.0 Language : English Default : Yes Forced : No Menu 00:00:00.000 : :Chapter 1 00:30:26.325 : :Chapter 2 00:37:10.895 : :Chapter 3 00:47:05.690 : :Chapter 4 00:48:16.827 : :Chapter 5 00:50:39.336 : :Chapter 6 01:06:33.723 : :Chapter 7 01:07:58.274 : :Chapter 8 01:30:24.753 : :Chapter 9 01:34:30.231 : :Chapter 10 02:03:13.119 : :Chapter 11 02:07:34.480 : :Chapter 12 02:37:15.860 : :Chapter 13 02:38:32.703 : :Chapter 14
Results 1 to 14 of 14
That's the default file layout mkvmerge produces.
https://mkvtoolnix.download/doc/mkvmerge.html#mkvmerge.file_layout -
So does that mean the seek entries being at the end aren't the problem? Why is this file impossible to navigate then?
The problem likely isn't the file but Emby. Make sure you are running the latest version. If you still have problems I would ask the Emby devs. Google brings up several hits for "emby mkv seeking". (I don't know anything about Emby myself.)
https://emby.media/community/index.php?/topic/80231-playback-issue-mkv-files/ -
Did you add the chapters using the "Multiplexer" tool ("Output" tab) or via the "Chapter editor"?
Try via "Multiplexer"->"Output" tab instead (or remux after adding the chapters as suggested by jagabo). The 2 ways to add chapters can result in different file layouts. (Whether or not that works around your problem is a different question.)
P.S.: 16 reference frames for 720x576 is perfectly within H.264 High Profile level 4.0. -
The issue is in the EBML header's seekhead entries. Mkclean, part of matroska.org resources, can correct the problem. Mkvinfo can list the results. Mkvalidator is also available.
How to end noisy MKV start?
By Paultx in forum Newbie / General discussionsReplies: 9Last Post: 19th Apr 2019, 13:28 -
Fixing subtitle entries that start after they end?
By bizzybody in forum SubtitleReplies: 8Last Post: 21st Apr 2018, 04:41 -
Any way to speed up a whole subtitle file? (identical start, earlier end)
By kilo in forum SubtitleReplies: 2Last Post: 14th Nov 2017, 16:14 -
I extracted aac audios from MPEG-TS file, and it is impossible to seek.
By lgblublu in forum AudioReplies: 1Last Post: 19th Dec 2016, 03:48 -
Seek issue on my mkv file
By Peaceinner in forum Video ConversionReplies: 1Last Post: 23rd Jun 2016, 01:36
