Not sure if this is in the right place but I sure could use some advice... Thanks
I am trying to take the split videos out of Chrome and Firefox caches and merge them back together again..
I have been using the videocacheview (.exe) and on 1 or two occasions it actaully combined the files and they worked.. but normally it fails to automerge.
So I tried the manual merge and that appears to merge but will not run. I even tried to copy them into another directory and use merging software to no success.
Matter of fact none of the individual split files will run either.. Is it possible I am dealing with videos that have been mangled to prevent merging or maybe a strange codec that I don't have..Any suggestions that i can try would greatly be appreciated. Surely in this large group of avid videoers will have some thoughts... Oh.. is there a way to determine if they are streaming and I might be able to capture them on the fly while streaming..
first: post video link, so we understand what kind of video / file you are talking about...
second: you play single file? with VLC or another? if yes to join It's not a problem, there are many programs that do this (free).
but if instead you can't see the single file, as i think, then it is encrypted, and here the discussion becomes more complicated...
but before continuing, explain better by answering the questions above.
How to share, auto-sort, cache videos/photos offline view?
By riu1 in forum Video Streaming DownloadingReplies: 1Last Post: 13th Nov 2015, 02:03 -
Adobe After Effects CC - Importing multiple videos without merging?
By LienFilm in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2015, 10:50 -
Merging 3 clips into one file, watching in split screen setting??
By RickyJogging in forum Software PlayingReplies: 3Last Post: 14th May 2015, 19:58 -
Merging / Joining videos of same / different encoding settings
By qaisark787 in forum EditingReplies: 5Last Post: 20th Apr 2015, 08:28 -
split/cut videos out with fade out effects
By sendspellme in forum EditingReplies: 1Last Post: 11th Feb 2015, 03:46
