  1. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    And the plus version is faster!
    TMPGEnc Plus Version 2.54 (2.54.36.134) Apr. 30 2002
    English HTML help has been included.
    The analysing result of Multi-pass VBR can be stored onto HDD cache to boost encoding speed. This can be specified at "Environmental setting".
    New "Cut Editing" feature has been added.
    At source range window, "[" key can be used for "Set start frame", "]" key can be used for "Set end frame" command.
    Vertical line Ghost can be reduced with new Ghost filter.
    At MPEG setting dialog, several settings can be locked/unlocked.
    Improved bitrate calculation : better result can be expected even if the number of frames in last GOP is fewer than usual.
    Bug fix : Invalid MPEG-2 file was created if vertical resolution is not multiple of 32 (which is not within MPEG-2 standard).
    Bug fix : Under Windows XP, closing "Marge & Cut" window caused memory access error.
    The file to download is 3072 KB
    Now, let's test! (avisynth/cce may wait a bit)
  2. The cut editing is really a great feature. I can now cut out commercials from the source range window and encode in one program. I used to have to use an editing program to remove the commercials from the timeline and them create a new AVI file without the commercials. This was all lossless but still time consuming.
  3. What's the different between "normal and "plus" version??
