Whoops! Good catch!
Responded sleepy just as I got up, no glasses. He he... 2 next to 3 next to 4...
Anyways, original post corrected.
Basically, anything off the dvd has 720 horizontal pixels of information and any reduction to 640 throws away some of that - thus, NO 640 pixel encode of a 720 source dvd video contains what you had. Better to encode to 720, and specify the correct par rather than 640 with a par of 1:1 to retain the most detail possible.
Results 31 to 35 of 35
@aedipuss
abolibibelot - your post #19 is a 16/9 source and needs to be re-encoded that way. you did it to 4:3 that's why a 1/3 of the video frame is missing.
@babygdav
There's also 4:3 letterboxed, in which case a crop of the top and bottom black bars helps reduce encoded file size since there's no video information of importance there. 1:1 pixel size depends on the crop and aspect ratio of the letterboxed video.
On the historical aspect of aspect ratios, I found this video very well made, clear and thorough :
https://www.youtube.com/watch?v=3CgrMsjGk7k -
Wow didn't think I'd get so many opinions, thought it'd be a straight answer lol.
https://www.streamingmedia.com/Articles/Editorial/Featured-Articles/Hardware-Based-Tra...aspx?pageNum=2
Generally, your initial handbrake settings are fine. Custom 0 crop, let it auto detect and set the rest.
Only improvement would be gpu accelerated encoding, if you have a Intel gpu with Quicksync, nvidia card, etc and have everything set in preferences to use the gpu to speed up encodes.
Else, cpu encodes will always work albeit slowly.
Fastest Way To SPLIT Video -NO Re-encode? -with ORIGINAL quality
By PeterGA in forum EditingReplies: 47Last Post: 21st Nov 2018, 10:33 -
Splice 2 MKV video files and retain original Surround Sound Formatting?
By Badger_1971 in forum EditingReplies: 1Last Post: 5th Mar 2018, 18:05 -
Encode DVD but use original PCM (not the AC-3)
By pooksahib in forum Video ConversionReplies: 6Last Post: 6th Oct 2017, 00:40 -
can QSVencc encode multiple .avs as source?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2017, 10:31 -
How to find .ts original source (m3u8 file)?
By atlantius21 in forum Video Streaming DownloadingReplies: 3Last Post: 30th May 2016, 07:47
