hello,
I'm looking for a software that allows me to capture a minidv tape by firewire, in one single file.
Does it exist ?
Thank you
Thank you
I have tried windv, but it seems that it capture with multiple segment file, I want just one big file.
Also, Im trying hdvsplit, I have some tapes with blank data between scenes (blue screen), this blue screen make the capture stop, is there a way with a software to capture an entire hour in one file.
Im looking for something similar of (vhs) analog capture but with firewire. -
In WinDV set discontinuity threshold to 0 and timestamps are then ignored. i.e one file is created.
http://windv.mourek.cz/index.html
You will also have to increase the No of Frames to transfer.
How can I losslessly capture video from an 8mm tape?
By Drew Neilson in forum Capturing and VCRReplies: 85Last Post: 29th May 2021, 02:22 -
How to capture PAL G tape and image stabilization?
By digicube in forum Capturing and VCRReplies: 13Last Post: 29th Jul 2017, 11:49 -
PAL tape capture - color issue
By nesburf in forum Capturing and VCRReplies: 3Last Post: 3rd Mar 2017, 12:41 -
What is more important regarding quality of mini DV tape video capture?
By nwgal65 in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2016, 23:23 -
8mm tape capture problem
By nesburf in forum Capturing and VCRReplies: 10Last Post: 12th Apr 2015, 12:46
