i installed potplayer as part of the "lav filers megamix" package and i'm a bit confused by the configuration....
in potplayer preferences > filter control > video decoder, everything is set to lav video decoder... when i click "built-in video codec/dxva settings" use dxva is enabled and dxva2 copy-back is also enabled.
in my taskbar tray there's an icon for "lav video decoder properties" and, when opened, i see that the settings are different than the settings in "built-in video codec/dxva settings" - for example hardware acceleration isn't enabled...
so my question is which settings should i use? and which settings take priority? the "lav video decoder properties" settings or the "built-in video codec/dxva settings"?
any help would be appreciated.
Results 1 to 1 of 1
Possible bug in LAV video filter
By cdb000 in forum Software PlayingReplies: 0Last Post: 1st Oct 2019, 16:08 -
Blurred strip at the lower edge of the picture with LAV Video Decoder
By abolibibelot in forum Video ConversionReplies: 7Last Post: 10th Dec 2018, 10:30 -
LAV Video + madVR = stutter
By slit in forum Software PlayingReplies: 4Last Post: 20th Sep 2018, 10:55 -
Using LAV Decoder for VirtualDub?
By Patriek in forum Video ConversionReplies: 8Last Post: 5th Nov 2017, 12:54 -
K-lite and LAV video decoder made a mess in my PC
By friendly_jacek in forum Newbie / General discussionsReplies: 6Last Post: 2nd Sep 2015, 16:13
