– In Windows, how can I remove the shortcut for the Magnifier feature ? Quite often I accidentally launch it when I want to type a closing square bracket, and it messes up the size of all windows as well as the disposition of the icons on the desktop, and I have no use for it whatsoever.
– I recently developped a severe case of allergy to the Windows session start sound, especially as it's supposed to have a cheerful tone, yet almost every time I hear it it's right after a BSOD and a forceful restart so I'm rather in the mood for punching something or rolling on the floor screaming. So where is it, and can I safely either blank it or replace it with something more in sync with my default mood, like a snippet from the third movement of Metal Machine Music, or “L.A. Blues” from Fun House on a good day ?
Last edited by abolibibelot; 14th Jan 2020 at 12:29. Reason: corrected typo in the title
I haven't tried it but a search found the following method to disable the magnifier shortcut here: https://www.top-password.com/blog/turn-off-disable-magnifier-in-windows-10/
Method 3: Disable Keyboard Shortcut for Activating Magnifier
AutoHotkey is a free macro-creation and automation-oriented scripting utility for Windows. Just create a simple script and you can disable the keyboard shortcut (Win & +) which can activate Magnifier accidentally. To get started, please check out the next post: How to Disable Any Shortcut Keys in Windows 10 / 8 /7Ignore list: hello_hello, tried, TechLord, Snoopy329
SVCD2DVD won't start in Windows 10 with 1809 update.
By lleader in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Mar 2019, 23:25 -
Old multi-session CD. 2 sessions. Only last session shows in Win. explorer.
By bteddy1 in forum Newbie / General discussionsReplies: 3Last Post: 20th Mar 2019, 10:19 -
Windows 7 CLSID to create a shortcut?
By flashandpan007 in forum Off topicReplies: 1Last Post: 4th Dec 2017, 12:14 -
Windows Live Movie Maker will not start
By ro2124 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2015, 10:59 -
Basic NRE for Windows that can re-encode at given start/end frames?
By yetanotherlogin in forum EditingReplies: 4Last Post: 26th Feb 2015, 03:44
