I've found a video where the audio track is compressed in MPEG Version2 Layer 3, while the common MP3 is in MPEG Version 1 Layer 3.
The result is metallic, and is not audible!
Is there a method to restore this audio track? I can use Audition but I cannot understand what can I do.
It's an MP3 file. https://en.wikipedia.org/wiki/MP3#Standardization
You probably can't do much to improve it. The damage was done when the file was compressed & data was discarded.
What are the details of the file? Sample rate, bit depth, bitrate? -
Depends on what you're trying to extract/keep vs remove.
https://new.steinberg.net/spectralayers/
https://www.izotope.com/en/products/rx.html
You'll likely exceed anything Audition can do with band pass filters and such. A spectral sound editor, or izotope would be the first place to start looking into advanced tools.
But, no idea what you have and what you're trying to do, so without a sample track, that's the best guess advice -
Mp3 means mpeg1 layer3, AND mpeg2 layer3. The part that mpeg2 added to the spec included support for higher & lower samplerates and higher & lower bitdepths, beyond what was already supported by mpeg1.
You didn't tell us the specs of the file but I can guess...
It probably is not corrupted/abnormal, nor is it an issue with player support (as literally everything supports both these days).
It probably was encoded to too low of a bitrate (e.g. <64kbps) for the material. If that is the case, then there is NOTHING you can do, other than go back to the uncompressed original (please hope you kept a copy), and re-encode with better settings.
I have never witnessed an attempt to "restore" the sound of an overly-compressed file that didn't end up robbing Peter to pay Paul, and mostly sound worse.
Is there a way to improve the quality of this video?
By ciccioschumacher in forum RestorationReplies: 7Last Post: 26th Jul 2018, 08:29 -
Help to improve the quality of the video
By ciccioschumacher in forum RestorationReplies: 0Last Post: 15th Apr 2018, 03:51 -
About using Merge() to improve quality
By Aludin in forum RestorationReplies: 13Last Post: 30th Dec 2017, 05:00 -
Improve the quality of video animation
By SB4 in forum RestorationReplies: 50Last Post: 15th May 2016, 15:10 -
Improve blurry low quality video into clear high quality video.
By Osram123 in forum Video ConversionReplies: 2Last Post: 4th Apr 2016, 02:48
