Hello,
I am making a DVD of a concert with Wondershare (that's the program my school has, can't get another one), and the menu isn't working how I need it to. I imported 4 seperate clips, and it automatically divided them into 4 chapters. However, when you click on scenes in the menu, it gives a menu with one choice. Clicking that choice brings you to the menu with 4 choices. Is there a way to fix this? I can't find anything on Wondershare's FAQs.
Thank you
I'm having the same exact issue. Anyone find a solution? I'm going to try uninstalling and re-installing the program and see if that works.
Wondershare DVD Creator help with set-up
By zhunter71 in forum Newbie / General discussionsReplies: 5Last Post: 30th Nov 2018, 04:16 -
Wondershare Filmora...AVOID
By ayoshak in forum Video ConversionReplies: 2Last Post: 15th Jul 2016, 08:25 -
wondershare
By trebdg1 in forum Video ConversionReplies: 3Last Post: 11th Jun 2016, 21:23 -
Problem with Wondershare Video Converter Ultimate
By pdun459 in forum Video ConversionReplies: 8Last Post: 24th Jun 2015, 15:07 -
Wondershare DVD Creator for Blu-Ray? Animated disc menus
By DarkPhoenix77 in forum Authoring (Blu-ray)Replies: 0Last Post: 19th Jun 2015, 02:59
