Results 1 to 14 of 14
  1. Not sure how to cut the MKV file losslessly, so I've made a lossless AVI of it. It was originally created from a DVD via MakeMKV.
    It lists with no interlacing information at all, so I pulled it into VDub and bobbed it TFF to check that TFF was correct...but it isn't. Every fourth frame of the resulting file jumps backwards. BFF doesn't work either. What's going on here?
    Here's the MediaInfo for the original MKV:
    General
    Format                                   : Matroska
    Format version                           : Version 4 / Version 2
    File size                                : 7.04 GiB
    Duration                                 : 2 h 48 min
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 5 997 kb/s
    Encoded date                             : UTC 2020-01-11 14:04:32
    Writing application                      : mkvmerge v40.0.0 ('Old Town Road + Pony') 64-bit
    Writing library                          : libebml v1.3.9 + libmatroska v1.5.2
    Video
    Format                                   : MPEG Video
    Format version                           : Version 2
    Format profile                           : Main@Main
    Format settings, BVOP                    : Yes
    Format settings, Matrix                  : Default
    Format settings, GOP                     : M=5, N=8
    Codec ID                                 : V_MPEG2
    Codec ID/Info                            : MPEG 1 or 2 Video
    Bit rate mode                            : Constant
    Bit rate                                 : 5 800 kb/s
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Variable
    Frame rate                               : 50.000 FPS
    Original frame rate                      : 25.000 FPS
    Standard                                 : PAL
    Bits/(Pixel*Frame)                       : 0.280
    Time code of first frame                 : 00:00:00:00
    Time code source                         : Group of pictures header
    GOP, Open/Closed                         : Open
    GOP, Open/Closed of first frame          : Closed
    Stream size                              : 6.81 GiB (97%)
    Writing library                          : TMPGEnc 2.524.63.181
    Default                                  : Yes
    Forced                                   : No
    Color primaries                          : BT.601 PAL
    Transfer characteristics                 : BT.470 System B, BT.470 System G
    Matrix coefficients                      : BT.601
    Audio
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Codec ID                                 : A_AC3
    Bit rate                                 : 192 kb/s
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 31.250 FPS (1536 spf)
    Bit depth                                : 16 bits
    Delay relative to video                  : 520 ms
    Stream size                              : 231 MiB (3%)
    Title                                    : Dolby Digital 2.0
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
  2. Plays fine in VLC for me too, but the Emby web player doesn't deinterlace it which is why I started investigating.
  3. Cut out your M2Vs using DGIndex and don't create useless MKVs.
    Why did you create a 50fps interlaced video for upload, with every other frame a duplicate? You didn't bob it. You only duplicated every frame. With the dupes removed it's just a normal TFF interlaced video.
  4. I didn't do anything to the attached AVI, I disabled the bob after testing in VDub.
    No M2V ever existed, I created an MKV using MakeMKV, as I said.
    Mar 2008
    Is it possible the conversion to Lagarith duplicated the frames? A simple script can restore fluid movement:
    LWLibavVideoSource("C:\Users\davex\Downloads\inter lacing.avi")
    selecteven()
    assumetff()
    bob() # or qtgmc
  6. No, the duplicated frames are in the original. Never saw it because I skipped straight to testing the field order. Throwing out either the odd or even frames and then bobbing still leaves a lot of combing though.
    And doesn't explain why there are duplicated frames in the first place. I was hoping to handle this without re-encoding anything, seeing as it's originally from a DVD and therefore should be DVD-compliant.
  7. Member DB83's Avatar
    Jul 2007
    Not really my subject but.....
    The original mkv might have had 50 fps yet the original dvd would have had 25 fps (even the mediainfo report states that). So the interlaced dvd became a progressive mkv with the duplicate frames.
  8. Originally Posted by koberulz View Post
    You created the MKV from the DVD? If so, my original statement remains; extract the M2V using DGIndex. The DVD wouldn't have been 50fps. If you didn't use the DVD, then extract the M2V from the MKV and use DGIndex to cut the sample.
    The reason neither TFF nor BFF worked for you was because you were "bobbing" the already ruined interlaced 50ps video. This whole thread is a waste of time. Have you learned nothing from your time here?
    No, it doesn't.
  9. It does for me. Specifically the edges of the red sign.
    I created the MKV from the DVD using MakeMKV, as I've said twice now. I'm backing my discs up onto a media server. I'm not actually trying to do anything with the video files, editing-wise, so why would I create an m2v? MakeMKV doesn't edit or convert or anything so the files should be identical.
    As for creating and M2V from the MKV, I don't know how to do that. tsMuxer gets me an MPV file, which DGIndex can open, but it won't let me cut a sample (the start/end buttons are greyed out).
  10. It's the way makemkv is packaging the mkv and timestamp handling.
    Some programs misinterpret the field rate as the frame rate, and you get these sorts of problems. It looks like vdub or whatever decoder you're using in vdub is having this issue, so the AVI has the duplicates.
    The original does not. I repeat - the m2v or original will not have that problem, and most programs will handle the original properly - you can be almost certain. This is a well known, and common problem with makemkv with interlaced mpeg2 in mkv container
    You can use mkvextract or some gui for it like gmkvextractgui to extract the .m2v , then use DGIndex
    DGIndexNV can properly read m2v in mkv container, but not free
    Because of the messed up timestamps . Because of the problems with interleaced MPEG2 in MKV. A large % of programs/hardware will not handle it properly. Like you're seeing right now.
  11. Originally Posted by koberulz View Post
    ...so why would I create an m2v?
    To create a usable sample.
    If that's the crap you put into your media server, better might be to giive it MPGs, if it'll play those okay.
    I don't know what you're seeing but it's almost - by definition - impossible for bobbed videos to display interlacing. Aliasing, maybe, or chroma bleed. Using this script:
    ChangeFPS(25)
    AssumeTFF()
    Yadif(Mode=1)
    I see nothing unusual around that red sign as the wrestler passes by.
  12. Originally Posted by poisondeathray View Post
    TBH it seemed okay on my TV, it just played back combed on the web and when I had a look at Emby's Media Info section it specifically says it's 50fps progressive. I was thinking I just needed to change a flag somewhere in the header or something.
  13. Originally Posted by koberulz View Post
    I bet the interlace flag is there in the original. If it's a retail DVD it should be.
    But "Writing library : TMPGEnc 2.524.63.181" suggests it is not, and it might not be a properly made DVD
    You can try restream or dvd patcher to flag it (but neither work on a MKV, you need ... surprise, surprise, a m2v)
