Hi, but I'm a ***
please consider the attached EdiusOUT.mp4 source:
mediainfo says
Video
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=30
Codec ID : avc1
Duration : 29 s 320 ms
Bit rate mode : Constant
Bit rate : 18.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 50.000 FPS
Original frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.174
Stream size : 63.2 MiB (98%)
Language : English
Encoded date : UTC 2017-11-30 23:02:40
Tagged date : UTC 2017-11-30 23:02:40
I need to build an .avs that "convert" it with an output 50P and YUY2 4:2:2.
The source is a 50i interlaced video file so I need to deinterlace and double framerate. Output have to be progressive.
How I have to do? thanks
Results 1 to 22 of 22
Your sample video already runs at 50fps and is interlaced. If you deinterlace for double frame rate the video will play at 100fps progressive, which is 2 times 50i. So if you want "double frame rate progessive", the only choice is 100p. Meanwhile your sample doesn't even play correctly and has horrible time code problems. I don't know about the original source, but someone has certainly ruined the mp4 sample. The sample is not workable.
- My sister Ann's brother -
You can use AssumeFPS(25) to "fix" the framerate
Otherwise it's the same as your other scripts for interlaced downscaling, reinterlace, (and colormatrix) . You've asked this question before -
This is common problem. The frame rate reported by MediaInfo is the field rate, not the frame rate. Many programs interpret this incorrectly. Exactly how you treat it depends on the source filter you use:
Code:LSmashVideoSource("EdiusOUT.mp4") AssumeTFF() AssumeFPS(25) Trim(0,framecount/2-1) Yadif(Mode=1, order=1) # or QTGMC
Code:ffVideoSource("EdiusOUT.mp4") Trim(0,framecount-1) SelectEven() AssumeTFF() Yadif(Mode=1, order=1) # or QTGMC
Interesting; slightly different results with different versions of lsmash / ffms2
There should be 733 frames, or 1466 fields (or bobbed frames) . The version of lsmash I'm using gets this correct, no need from the trim -
With the versions I have the source filters screw up near the end of the clip. Hence the trims. Lsmash is a few years old -- I should probably update it.
By the way, I was using a 64 bit build of AviSynth+.Last edited by jagabo; 13th Jan 2020 at 05:56.
The one I'm using is here
https://github.com/HolyWu/L-SMASH-Works/releases
GPU decoding works for this branch too
LSmashVideoSource() is usually consistent for MP4, but there are some errors on non linear seeking here . LWLibavVideoSource() with the indexing works -
Thanks for the link. I updated and use LWlibavVideoSource() and new the Trim() isn't necessary.
Code:LWlibavVideoSource("EdiusOUT.mp4") AssumeTFF() AssumeFPS(25) Yadif(Mode=1, order=1)
You're correct LSMASHVideoSource() has trouble with random seeks. It also has problems with the two leading B frames with negative time codes (the video was cut from an open GOP source) -- it repeats the initial I frame for each of those. LWlibavVideoSource() is smart enough to skip those frames.
(I don't mean to hijack the thread of a ***, but since the *** has been sleeping for about 24 hours...) -
It might be that specific version;
In my experience LSmash is way more consistent than FFMS2 for transport streams. Especially interlaced AVC. All versions were. FFMS2 readme warns about this
There is a python super duper random seek script and excel spreadsheet with results tabulated by chaosking, and almost all versions fail seek test except certain versions of LSmash.
Hard to say , because you have a monster script, a gazillion calls. -
oh my ***
[Attachment 51455 - Click to enlarge]
what is "framecount"? is it calcutated from a batch script? -
https://www.mediafire.com/file/pvojgkqxu4t8mii/20151224_145719.m2ts/file
Here is FrameSurgeon with the currently installed versions of the associated plugins :
FrameSurgeon + associated plugins (32 bits).7z
And here is the FrameSurgeon command file used for this video file :
20151224_145719 FrameSurgeon.txt
To reproduce the issue (unless it's somehow specifically related with my system, or unless the whole reality is just an illusion and we are the figments of the imagination of a sleeping ***), load the script in AVSPMod, go to frame 240 and refresh, it should show a wrong frame (the first frame of the video actually), then scrub backwards to frames 237-239 (interpolated from 236 and 240 according to the "I3 237" command) to see them weirdly scrambled. Or if you refresh on frame 241, frame 240 appears as a duplicate of frame 241, and frames 237-239 appear almost normal but not properly interpolated (= slightly blurry). Or if you scrub back and forth repeatedly around those frames (but this is harder to reproduce, seems more random), they may start to stutter and the interpolated frames 237-239 will appear extremely blurry. This doesn't happen with FFVideoSource.
Code:LoadPlugin("C:\Logiciels autonomes\MeGUI\tools\lsmash\LSMASHSource.dll") LWLibavVideoSource("G:\[path]\20151224_145719.m2ts", threads=1) FrameSurgeon(cmd="G:\[path]\20151224_145719 FrameSurgeon.txt", show=false)
EDIT : I forgot to include the version of LSMASHSource currently used, which is the one in MeGUI's "tools" subfolder (dated 2017-02-24) :
LSMASHSource (from MeGUI).7zLast edited by abolibibelot; 13th Jan 2020 at 16:44.
[Attachment 51459 - Click to enlarge]
but can FrameSurgeon replace (for example)
Code:SmoothFPS2(50000,1000)
and however I wonder: this strange condition of "ambiguous framerate" .. e.g "Frame rate : 50.000 FPS
Original frame rate : 25.000 FPS" is common also for porogressive sources ?!?or affects only interlaced ?!?
I've only seen this particular problem (confusion over the true frame rate) with interlaced video with Scan type = Separated fields. It's not uncommon.
Very weird indeed. You don't need any scripts, just source filter. Go to frame 240. Refresh .
Affects several Lsmash versions, x86, x64, including the latest. Threads=1 too. Both avs/vapoursynth versions too
But only CPU. GPU decoding via Nvidia/CUVID works (decoder="h264_cuvid") with those newer branches work (with the framesurgeon script too). What a flip flop! It used to be GPU decode quite unstable in lsmash, very flaky. (And DGDecNV, the "gold standard" works of course here too)
(FFMS2 works here , as you reported, several versions. But beware it has many more "fails" than Lsmash overall across all scenarios)
It might be related to the frame repeat flag in your video. But problem still persists with repeat=true and selecteven() or selectodd()
With your permission , I'd like to report this lsmash CPU decoding seek issue with your sample video - it's the only way things get "fixed" . And there is an active developer around right now.Last edited by poisondeathray; 13th Jan 2020 at 19:06.
If that matters, the video was shot with a Panasonic ZS7 / TZ10 compact camera.
Perhaps send me a private message if there's some feedback somewhere at some point...
Could you figure out why it affects this frame in particular ? Is there a way to systematically detect those problematic frames ? I tried SeekTester (suggested on the Doom9 thread) but only got a "script error" message (tried several source plugins, several file formats), don't know if I did something wrong.
@ marchorocchini
[SOLVED] [ffmpeg] How to build a 5s MP4 from JPG to match video file?
By yetanotherlogin in forum EditingReplies: 4Last Post: 8th Oct 2018, 17:29 -
can QSVencc encode multiple .avs as source?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2017, 10:31 -
Mp4 Playback Choppy In Firefox Since Downloading New Build of ffmpeg
By Bruce Wayne in forum Software PlayingReplies: 10Last Post: 11th Apr 2016, 17:33 -
Add audio stream to MP4 from a different source.
By baglio in forum Video ConversionReplies: 2Last Post: 6th Apr 2015, 12:57 -
Create .avs files for MP4 and MKV to open in VirtualDub
By A2000 in forum Video ConversionReplies: 3Last Post: 24th Jan 2015, 08:59
