I have a folder with 500 video files, in varying formats.
I would like to discover the details of the the main audio stream in each of the video files.
I can open each video file in MediaInfo but it would take a long time to do that for that many files.
Ideally, I'd like a text document (or something on-screen) that lists each video file and the details of it's primary audio stream.
Can MediaInfo batch this for me? Or is there an alternative way?
MediaInfo can open a folder and display the contents of each media file (may take a while to analyse them all).
With MediaInfo CLI you can create a text file for each video file. For instance :
Or if you want a single text file, define a single name for the .txt output and use two ">" signs (to add content to the file instead of overwriting it) :Code:FOR %F in (*.avi *.mp4 *.mkv) DO "[X:\Path\to\MediaInfoCLI\MediaInfo.exe" "%F" >"%F - MediaInfo.txt"
The basic output may be good enough but the CLI version also allows to dump every available field with the -f option, or to use a custom template with the --Output option.Code:FOR %F in (*.avi *.mp4 *.mkv) DO "[X:\Path\to\MediaInfoCLI\MediaInfo.exe" "%F" >>"Mediainfo.txt"
For instance I used this template (saved as .csv) for a particular set of AVI videos :
Code:General;Général\r\nNom complet : %CompleteName%\r\nFichier créé : %File_Created_Date_Local%\r\nFichier modifié : %File_Modified_Date_Local%\r\nConteneur : %Format% (%Format/Info%)\r\nTaille : %FileSize% (%FileSize_String4%) \r\nDurée : %Duration_String5%\r\nDébit global : %OverallBitRate% (%OverallBitRate_String%)\r\nFlux vidéo : %VideoCount%\r\nFlux audio : %AudioCount%\r\n\r\n Video;Vidéo\r\nFormat : %Format%\r\nRésolution : %Width% x %Height%\r\nRatio : %AspectRatio_String%\r\nCadence : %FrameRate% im/s\r\nImages : %FrameCount%\r\nDébit : %BitRate% (%BitRate_String%)\r\nBits/(Pixel*Cadre) : %Bits-(Pixel*Frame)%\r\nTaille du flux : %StreamSize% (%StreamSize_Proportion%)\r\n\r\n
RECentral: Audio Steam Not Capturing / Saving
By bzowk in forum Capturing and VCRReplies: 4Last Post: 26th Jun 2019, 23:00 -
Playing next video files from the current folder with MPV?
By Noctis001 in forum Software PlayingReplies: 12Last Post: 11th Nov 2018, 12:22 -
Need Help Changing the Default Audio Stream for Hundreds of MKV Files
By ballsoup in forum AudioReplies: 11Last Post: 19th Apr 2016, 15:53 -
Extracting All Video/Audio File details/attributes to a text/Excel list
By liquid65 in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2015, 08:27 -
Extract audio files from an SACD ISO folder
By mikeos in forum AudioReplies: 7Last Post: 21st Apr 2015, 17:20
