I want to create a video of 24 frames from a single jpg, but hybrid keeps saying the video crashed and aborts. The thing is, I had successfully done this with Hybrid a few months ago. So I can't tell what I'm doing wrong this time.
On the Hybrid main window, I tick the Image Sequence box to switch the source selection to Image Sequence Selection. Then, on the image sequence selection window, I tick the Single Image box and select the 1st Frame image as the image for the whole video. Next, I set Frame Count to 24 and Frame Rate to 23.976 (24000/1001) Click on Accept. Set Output filename on the main window. I've already used the same encode settings to encode other videos for the past few days, they work. Yet, this one won't. When I tell Hybrid to start on the job, it just crashes the video shortly.
Please help me figure out what I'm doing wrong.
I am aware I can use ffmpeg in commandline as an alternative to create an mp4, then convert it to a video of the correct encode with hybrid, but that doubles the time spent on this operation. So I would prefer to do it in a single step with Hybrid.
Can't really tell what is going wrong.
Would need a debug output (best level 9) of the job processing.
read: http://www.selur.de/support
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
btw. just release a new version which fixes a Image Sequence bug another user reported, so that version might fix the issue here,..
That looks awesome. Are you able to add color in old movies and photos too that way? I was looking for a way to colorize photo of a client that brought me a 70s picture of his family and would pay well to have it made in color. I couldn't find any program that would be of high quality for such a task. I had to call a few friends who did this kind of work before and told me that imagecolorizer is a great one to do such work. I just wanted to see if there were other similar apps or programs that I could use as I always like to have alternatives.
No, Hybrid has no option to colorize images or a video.
You could:- convert your video stream into an image sequence using Hybrid
- Use something like https://github.com/jantic/DeOldify or https://github.com/ericsujw/InstColorization to colorize the images
- import the colorized image sequence into Hybrid
If someone implements Vapoursynth filters which uses DeOldify or InstColorization I'll be happy to add support for those in Hybrid, but I will not try to add either of those in Hybrid.
video mkv HDR colors incorrect with staxrip, Hybrid and others
By jonrodrigos in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2019, 03:48 -
Creating a SD card image file on Mac
By divo2000 in forum MacReplies: 3Last Post: 15th Sep 2018, 17:27 -
creating MDF image for an old CD disc
By kenny1999 in forum DVD RippingReplies: 1Last Post: 28th Jan 2017, 14:52 -
Creating a simple still image movie for DVD-Audio disc
By DRP in forum Authoring (DVD)Replies: 29Last Post: 30th Aug 2015, 21:01 -
Creating Image Panel or Array
By box-turtle in forum EditingReplies: 5Last Post: 1st Apr 2015, 04:15
