Hi. I'm converting a bunch of old family VHS tapes to digital format. I'm saving them in WMV files (so I can edit in Moviemaker). What audio setting do I use when saving? So Many to choose from. The save screen defaults to Windows Media 9 for Color Pocket PCS (225 kbps). The Video defaults to Windows Media Video 9 and the Audio defaults to Windows Medial Audio 9.2 but there is no "format" and several to choose from.
Which would I use or is it a hit and miss situation? I'd hate to wait all the time to save the clip and find out the sound was bad. Thanks.
Thank you. I will try this. Maybe it will help in the lack of sync with the sound and audio as well. Wondering if I should save them to AVI instead of MPEG or WMV. Your opinion?
Save to AVI only if lossless AVI. If you don't intend to ever edit and/or improve the video, then MPEG might be okay. Just my opinion.
I feel you, LMotlow. I had to double-check I hadn't fallen into a timewarp when I clicked on the OP.
Why edit in Movie Maker? I find VirtualDub better. I am not sure, but maybe Windows Movie Maker can import AVI files, at least when compressed to the standard formats such as M-JPEG with PCM audio.
Newbie - errors on some not all VHS to DVD conversions.
By Quaffin1 in forum Video ConversionReplies: 4Last Post: 17th Feb 2018, 15:27 -
Which settings would you compress these VHS rips to?
By kingmustard123 in forum EditingReplies: 3Last Post: 10th Sep 2017, 20:48 -
don't know what to do [VHS to MPG conversions need some work]
By catsmeow in forum Newbie / General discussionsReplies: 6Last Post: 6th Feb 2017, 02:04 -
How to edit audio-stream using chapter-info and save as one audio file?
By Mazuda To Yo Da in forum EditingReplies: 4Last Post: 24th Apr 2016, 18:53 -
Help I'm trying to convert some VHS tapes to DV then save them on my PC
By BirdDaddie in forum Capturing and VCRReplies: 10Last Post: 18th Jan 2016, 01:57
