Hi, I just connected an old SVHS Panasonic AG 5700 after not using it for some time and I only get a message on the small screen "sensor". Nothing else turns on. Should something else turn on when pressing power? Thank you.
There is a switch on the top left of the rear panel labeled "SENSOR REC" - if it is in the ON position, turn it OFF.
You should then be able to use the VCR normally.
The SENSOR REC mode puts the 5700 into a sort of recording standby zombie state, waiting for the signal from a compatible source to automatically trigger start and stop of recording.
Auctioning my Panasonic AG-DS555 S-VHS deck
By houstonian73 in forum Off topicReplies: 1Last Post: 10th Jun 2019, 01:40 -
Authoring using the Panasonic DMR-BWT720 deck...
By Gil T Remnant in forum Authoring (Blu-ray)Replies: 2Last Post: 29th Dec 2016, 16:31 -
Panasonic AG 5700 seems to stutter with EP mode tapes
By Knightmessenger in forum Capturing and VCRReplies: 4Last Post: 1st Nov 2016, 17:36 -
Need advice on Panasonic FS100 quality (SVHS)
By Topsy in forum RestorationReplies: 7Last Post: 25th Oct 2016, 02:08 -
Component from svhs deck?
By Bassquake in forum Capturing and VCRReplies: 2Last Post: 13th Jul 2015, 19:12
