Obsolete
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Results 1 to 9 of 9
not unless you still have the originals
Messed up how?
The audio doesn't sync with the people talking and such?
Or it sounds wrong?
If it's the first, yes.
You'd have to cut the audio out for each clip section, resample it to match the video, combine. You'd use markers on the video and audio tracks indicating key points to align both. -
That's Nice!
But I wonder what format the audio is in....
Right-click on the file, properties -> under the details tab I believe.
Or
Try media player home classic mphc.
Play the file, right click on the window, properties -> last codec tab.
What format, bitrate, is the audio?
(E.g. Mp3 44.1khz 320 kpbs)
What program did you use to create it?
Very odd vlc doesn't play it correctly, so want to make sure nothing's wrong for the future for the settings. -
I guess media info has more info so here you go: Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Duration : 3 h 13 min
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : -46 ms
Title : Stereo
Default : Yes
Forced : No
Edit: Solved the problem by changing the audio codec using ffmpeg: ffmpeg -i 1.mkv -acodec mp3 -vcodec copy out.mkvLast edited by Felow; 8th Jan 2020 at 23:49. Reason: Solved
Nice!
Stick with tried and true codecs like MP4 and MP3 to prevent major issues. These are almost dummy proof.
As for combining videos with different bitrates, resolutions, and such, usually, most modern, top video editors like Adobe Premiere, Avid Media Composer, Vegas Video, and Blackmagic Davinci will let you add them all onto one timeline, export to one combined, properly playing file.
Of these, two are free - Avid Media First and Blackmagic Davinci. Try Blackmagic first since it has recently added a powerful audio editor.
If you use ffmpeg, certain switches may be useful - video_track_timescale, itsoffset, concat, ar, asetrate.
Because there are so many recording bitrates, frequencies, bit depths, formats, etc, etc., you will have to manually confirm the sync of combined clips until you get the hang of whatever you need to do to get those clips to combine properly.
However, it can be far easier to drop the videos into Blackmagic (and even if just for the audio, export the combined audio track into a file you can combine with the videos in ffmpeg.).
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 06:43 -
How to Fix Audio Sync With Videos
By Daringbaaz in forum Newbie / General discussionsReplies: 0Last Post: 24th Jul 2019, 00:44 -
Can anyone help fix the audio leveling of this ?
By TheRandomOne in forum AudioReplies: 15Last Post: 29th Nov 2018, 07:30 -
Skips in audio fix?
By mtepper27 in forum RestorationReplies: 1Last Post: 23rd Jul 2018, 15:54 -
how can fix it? [AUDIO]
By enable in forum RestorationReplies: 10Last Post: 30th Jan 2018, 13:07
