    Jan 2020
    Chaleston,WV
    Hi,I copied a home video with my Magnavox ZV427MG9 VHS/DVD COMBO and the dvd disc works find with my tv/dvd player and was wanting to know the best way to make additional copies that will work on stand alone dvd players for our family without having to re-edit with the combo,or would it be best to copy the dvd to a vhs tape and make the copies that I need from the vhs to dvd?I'am new to this technology and was needing advise from people like you that knows best",my thanks in advance"
    Aug 2006
    Do you have a Windows PC with a DVD drive that can burn discs? If so, you could try running ImgBurn to copy your original DVD
    as an ISO to your hard drive, and then use ImgBurn to make copies by burning the ISO to blank DVDs.
    Guide: http://forum.imgburn.com/index.php?/topic/6380-how-to-copy-a-disc-using-imgburn/
    Feb 2006
    make sure that you finalize the disc in the VHS/DVD combo before you try to make copies.
