I-frame
Independently encoded frame (so can be decoded independently), just like a static image.
P-frame
Predicted frame based on the interpolation from one or multiple previous frames in the presentation (display) order.
B-frame
Bi-Directional P-frame based on the interpolation from other frames (including later frames in the presentation order).
Note: the decoding frame order and the presentation frame order don't have to be the same, which is the foundation of B-frame.
B-Pyramid
The analogous term describing the behavior of continuous B-frame referring (a B-frame refers to B-frames refer to B-frames...).
For a graphic demonstration, see this.
Slice
A portion of a frame, which is encoded either independently (I-slice) or based on only one of the other frames (P/B-slice).
Which is the smallest unit of a frame.
IDR
Instantaneous Decoder Refresh, no frame after which should refer to the frames before the point. (in the decoding order)
Which imposes limits on the frames available for the Inter interpolation.
Note: this property doesn't have to pertain to a certain frame type.
DPB
Decoded Picture Buffer, which is used to store the decoded frames by the decoder.
The size of DPB imposes a hard limit on the max permitted encoding complexity.
Scenecut
At which point the Inter interpolation is considered less effective than a simply I-frame placement. (so is an I-frame inserted instead)
Results 1 to 1 of 1
Star1000 integration time explanation
By addi II in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2019, 05:00 -
Request MKVToolNix GUI popup "adding or appending files" dialog explanation
By JBC in forum EditingReplies: 1Last Post: 6th Jan 2018, 14:43 -
AviSynth+ running 6 times faster one time without explanation?
By mleise in forum RestorationReplies: 4Last Post: 14th Sep 2017, 14:34 -
DVD's PAR and output display size explanation in Handbrake
By Superfrank in forum Video ConversionReplies: 3Last Post: 11th Feb 2017, 17:27 -
Best Explanation how Keyframe Interval works?
By kairukun in forum Video ConversionReplies: 4Last Post: 19th May 2015, 17:14
