Trying to convert a few VHS tapes to digital using the easyday DC60. VCR has composite in and SCART out but no composite out besides audio. DC60 requires composite in or S-Video in. Ideas? Maybe a SCART-to-S-video or SCART-to-composite?
Results 1 to 9 of 9
Are you sure you plugged it into an output port and not an input on the VCR?
Scart to S-video propably won't work (or rather will give you a black and white image), unless you happen to have a SVHS VCR. If scart to TV works, a scart to composite adapter would probably work as well. -
Scart to s-video will only give you a black and white signal unless you have a high-end SVHS machine that support s-video output on the scart port (in which case there will be a menu setting or switch to switch between composite and scart).
Yes, if the VHS deck has s-video output there will be a setting in its menus. This is because the composite and s-video luma (greyscale) pin are shared at the SCART connector. So the device needs to know which signal you want to output. That shared pin is also the reason you get a black and white picture when you try to capture s-video from a deck that doesn't support s-video output (there's no color on the chroma pin). Or when you attempt to capture composite from a device that's putting out s-video.
SCART to S-Video didn't seem to work at all, not even black and white. SCART to composite worked. Thanks for the help.
A Blu-Ray player & VCR connected together, VCR input settings?
By Kzzrn in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2019, 11:15 -
M3u8 channels not working in Samsoung smart tv but working in vlc player
By alaasl3 in forum Video Streaming DownloadingReplies: 18Last Post: 15th Apr 2019, 04:47 -
I want to learn VCR repair PANASONIC VCR maintenance information Books With
By 280634157 in forum Capturing and VCRReplies: 9Last Post: 18th May 2018, 17:20 -
Need advice about VCR to PC connection.
By alexinho25 in forum Capturing and VCRReplies: 10Last Post: 13th Aug 2017, 13:30 -
VHS tape got stuck in VCR, now VCR plays full static
By Rand251 in forum Newbie / General discussionsReplies: 21Last Post: 4th Apr 2016, 10:40
