obsolete
Results 1 to 16 of 16
It should not unless the bitrate is to low to show the textures properly.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
see: https://x265.readthedocs.io/en/latest/cli.html
strong-intra-smoothing=0:rect=0 means both options are disabledusers currently on my ignore list: deadrats, Stears555, marcorocchini -
@gdgsdg123:
If a features caused 'unnecessary blurriness' on an old version it does not really say much, especially since:
a. it's totally unclear what qualifies as 'high bit rate applications' (resolution, settings, content are all unknown)
b. not knowing what version this was (a lot happened during 2019, including the introduction of sliced based sao; different settings might change things)users currently on my ignore list: deadrats, Stears555, marcorocchini -
Yes it still blurs in 2020. But not as bad as before. Personally I still don't like it
To disable all , it's --selective-sao 0 --no-sao now.
SAO tends to blur smaller higher frequency details like fine hairs, skin pores, even at typical bitrate ranges. The trade off is slightly more artifacts. But I prefer details > smooth . Some people prefer smooth, that's ok too . You will typically see the blurring for 10bit x265 CRF 23-24 slow as per the OP's scenario , at least on still frames for typical live action sources. In motion, depends on the person.
But for low to very low bitrates, or "smooth" content like simple cartoons it can be beneficial (but so can a denoiser)
Those are just generalizations; it's always better to do some tests and check for yourself for your specific sources
(Handbrake still does not have a 10bit pipeline in 2020. Don't use it if you have a true 10bit source.) -
For sample previews, check my YouTube channel. (I keep higher quality versions locally)
After various testing I choose to stick with x264 as x265 actually yielded worse result (both efficiency and quality wise) for my usage. (maybe because I don't know how to use x265... more likely because x264 works too good for me) -
Looked channel, no details about resolution and settings.
-> it's probably best Felow tries with his content and decides for himself.users currently on my ignore list: deadrats, Stears555, marcorocchini -
What I was using (for quality export):
%INPUT%: RGB24, 30 FPS VFRCode:ffmpeg -i "%INPUT%" -c:a aac -b:a 320k -c:v libx264 -r 30 -preset placebo -tune film -crf 19 -x264-params "level=5.1:keyint=150:qcomp=0.75" -pix_fmt yuv420p -sws_flags spline+accurate_rnd+full_chroma_int -vsync vfr -color_range 1 -colorspace 5 -color_primaries 5 -color_trc 6 "out.mp4"
Input resolution: 5120x1440, 2560x1440, 1920x1080
Note: I use different commands for YouTube uploading and quality export. -
I have made a more meticulous test and the difference is negligible so I'll just stick with SAO enabled here is the comparison: https://imgur.com/a/sajWHXh
That would be acceptable for me too.
But it's a lower quality 5Mb/s 1920x1080 source. There are already compression and banding artifacts; high frequency details are already missing in the source (essentially it's already been pre blurred or lowpassed, so there is not much to lose)
When people complain, it's usually a higher quality source that loses significant fine details after encoding
Hevc Encoding Which Gpu
By hdfills in forum Video ConversionReplies: 21Last Post: 17th Jul 2019, 06:01 -
Encoding hevc video : Bd-rebuilder
By K.S.LEE in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2018, 04:08 -
Hevc encoding...
By dragonpilee in forum Video ConversionReplies: 2Last Post: 6th Jan 2017, 08:49 -
FFMPEG 12bit hevc encoding
By aniruddh in forum Video ConversionReplies: 14Last Post: 31st May 2016, 04:08 -
HEVC Hardware Decoding/Encoding
By jmdale1984 in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2015, 23:58
what about "strong-intra-smoothing=0:rect=0" what does it do? it was activated on the default preset.
