    May 2010
    Albany, CA USA
    What is the minimum size of SSD (in GB) required for downloading and burning to DVD a typical two-hour movie? I'll be using MX Linux on this SSD, which I think is about 3 GB in size, so I'll add this to your answer. Thanks.
    Weird question.
    I was making DVDs back when a "large" HDD (IDE) was 100gb.
  3. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    Why do you want an SSD? It is not required to do what you need.
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
    Jul 2007
    9GB which is more space than on a DVD-9
    But as asked above, why? The smallest SSD I've ever seen (and used) was a really old 8GB one I used on an old Dell laptop.
    Edit: For anyone that would ask me why? It was to create portable MAME machine to play old arcade games when the largest Android tablet screen size was 7". My laptop is 14 or 15". I put a minimal XP install on the SSD (IDE BTW) and [used] a flash drive for the MAME files.
