Hi,
I'm new to video editing, and trying to remove the music from a sequence in the Avengers movie. I've got the movie clip with 6 channels, however when I import it into Audacity I can't mute the music, because all the tracks contains both music and sound effects. Is this normal, and is there some other way around this?
I've attached a random sequence from the movie, if anyone wanna have a look.
Thanks!
WHat you see is completely normal, there are no separate music/effects layers or channels. There's also no software that can tell the difference.
The different audio tracks are to produce spacial effects, they are the same recording (or studio edit of it) but taken from microphones pointing in different directions. They are not different component parts of the sounds you hear but each contains a portion of the whole with appropriate delays and levels to reproduce the surround sound effect.
Brian. -
That makes sense. So I guess there is no way to remove the music then, bugger :\
But thanks anyway!
Any Way to Remove Music from MP4 Soundtrack?
By pone44 in forum AudioReplies: 4Last Post: 13th Aug 2019, 12:55 -
Weird problem converting / extracting Marvel's The Avengers Blu-Ray
By EmmB in forum Video ConversionReplies: 0Last Post: 8th Jun 2019, 21:31 -
Backing Up Marvel's The Avengers???
By Kissjp in forum DVD RippingReplies: 5Last Post: 27th Mar 2017, 02:08 -
Remove vocal from a music video or a song
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 1st May 2016, 20:16 -
how to remove bgm music and only keep the sound effects
By quatro in forum AudioReplies: 7Last Post: 1st Nov 2015, 23:41
