    Jan 2020
    Admin Knows
    Hi to all
    i m playing stream at home with vlc but is not running good.stoping and reapiting the scene !!..
    reading log see this message
    Non-monotonous DTS in output stream 0:1; previous: 28508004, current: 28507105; changing to 28508005. This may result in incorrect timestamps in the output file.
    i dont knwo reaaly wats mean any explication are welkom and how i can solve this !!?
    Thanks in advance
    Cheers
    Jan 2020
    Admin Knows
    is a normal issue i dont thing so !!!! because the stream is not playing good like freezing stoping
  3. Member DB83's Avatar
    Jul 2007
    A link to the actual stream might help.
    Even so, are you trying to record this stream at the same time as playing it. The error you report suggests a bad/unfixable stream but it could be your connection which is why others should look at it.
    And do a search for "Non-monotonous DTS in output stream 0:1" will offer some explanation but few, if any, fixes.
