  1. I don't know either my system having trouble to play video which is encoded very slow preset or my subconscious mind saying my encode is just bad. do you seeing picture frame skipping or something or it's just normal? and please check the media info should i change anything to make the video quality better?
    https://www71.zippyshare.com/v/4MIcYRoM/file.html
    here is the media info
    HTML Code:
    General
    Complete name                            : test.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom (isom)
    File size                                : 23.1 MiB
    Duration                                 : 51 s 133 ms
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 3 796 kb/s
    Encoded date                             : UTC 2020-01-02 15:20:40
    Tagged date                              : UTC 2020-01-02 15:20:40
    Video
    Format profile                           : High@L4
    Format settings, RefFrames               : 4 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 3 636 kb/s
    Nominal bit rate                         : 4 000 kb/s
    Maximum bit rate                         : 16.6 Mb/s
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 (24000/1001) FPS
    Bits/(Pixel*Frame)                       : 0.073
    Stream size                              : 22.2 MiB (96%)
    Writing library                          : x264 core 157 r2935 545de2f
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=0 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=31250 / nal_hrd=none / filler=0 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Encoded date                             : UTC 2020-01-03 00:16:02
    Color range                              : Limited
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 51 s 113 ms
    Bit rate mode                            : Variable
    Bit rate                                 : 156 kb/s
    Nominal bit rate                         : 176 kb/s
    Maximum bit rate                         : 268 kb/s
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Stream size                              : 973 KiB (4%)
    Title                                    : Surround
    Language                                 : English
    Encoded date                             : UTC 2020-01-03 00:13:55
  2. Nothing wrong with the file.
