Hi...
Im having much trouble to find a good way to convert the DivX Files into an VCD in a good way.
For now i use DivXDoctor to convert them into .mov. That works great.
To cut and Convert them into mpeg1 i use Quicktime Pro. And there are starting my Prolems:
- Quicktime doesnt really remember my settings about the Quality
- I have to wait till the first part of the Movie is exported (around 3-5 Hours) to convert the next File. Isnt there a way to use some kind of cue?!?
- Some real great DivX become real shitty quality on VCD, others not, some are better quality if i let Quicktime export them again.
Does anybody know an other Program for this Job?
Tnx and Greetings
DJ-Kolchos
Uh.. Why don't you just use TMPGEnc to convert DivX directly to VCD? What's the point of sub-converting it to QuickTime Movie?
Hmmm... Good question... I thought its only for Windows. I found out that it was an mistake.
How would be the way to convert a DivX to an VCD?
Also going through the way of converting it to an .mov?
I found out that many DivX have problems to get played directly on the Mac. But i also found out that if i convert it into .mov i can play all the files like i want.
Does TMPGEnc has the same nice feature like no problems with the DivX i have problems with?
Is there an useful GUI for that program too? And what about the function cue and automatically cut the files???
Many questions i know... I hope u can help me out with it...
Tnx anyway
Greetings DJ-Kolchos
Originally Posted by Jeomite -
Ok... And more confused again... There isnt an TMPGEnc for Mac... :(
Is the way u mean VCDImager? I took a look on their Webpage, but there i found nothing on whether and how it would works with DivX... :(
Greetings
DJ-Kolchos
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
joining tools (preferably with flv/mov support + others)
By lordrt in forum EditingReplies: 3Last Post: 20th Aug 2010, 11:53 -
DVD to Divx with the following tools
By climbs in forum Newbie / General discussionsReplies: 3Last Post: 16th Dec 2008, 23:19 -
Tools for authoring several divx files in a disc
By Paco M. in forum Newbie / General discussionsReplies: 10Last Post: 13th Jun 2008, 17:33 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48
