Hey guys, I am using Windows10. I ran into some problems capturing in VirtualDub since I have built my new setup and was kinda forced to go with Windows 10 (the crap that these motherboard companies are pulling to make people have to upgrade to 10) Anyways, someone recommended that I find VirtualDub2. I did and it works just fine..... But I have something that I want to use the median filter on and it will NOT load no matter how I try. I am met with an error. It is a .VDF file. Any suggestions?
[Attachment 51319 - Click to enlarge]
THe one from here?
http://www.infognition.com/VirtualDubFilters/denoising.html
Seems to work if you load it into the 32 bit version of Virtualdub2 -
I tried that one and came up with the same thing. I even deleted my VirtualDub folder and made a new one by unloading the archive file and it came up as the same thing. Windows 10 is so frustrating to me right now. Everything worked just fine on Windows 7.
You apparently have a 64 bit median filter meant for 64 bit VirtualDub. You need a 32 bit version for 32 bit VirtualDub.
Median() plugin for Avisynth
By ajk in forum RestorationReplies: 74Last Post: 17th Mar 2020, 13:53 -
Avisynth+ not refreshing in VirtualDub2
By Chief Mouse in forum Video ConversionReplies: 2Last Post: 6th Sep 2019, 16:18 -
Having a problem with VirtualDub2
By Bruce Banner in forum EditingReplies: 9Last Post: 19th Aug 2019, 14:19 -
VirtualDub2 plugins
By foldbck123 in forum Newbie / General discussionsReplies: 14Last Post: 21st Nov 2018, 03:29 -
audio/interleaving/delay audio in Virtualdub2/Filtermod & filter weirdness
By davexnet in forum Video ConversionReplies: 2Last Post: 19th Apr 2018, 11:28
