For some reason, I have a Digital8 camcorder that just zooms in for no reason at all. Even the zoom meter on the camera's LCD shows that it's zooming in. Nothing I do seems to get it to zoom out. The zoom control isn't stuck, I can move it just fine. I hope this can be fixed easily and it's not a problem with the actual camera lens.
	I had a a Canon Hi8 camera that did that. In my case it was due to wear in the zoom control switch
	It doesn't matter where I have the zoom control switch pointed at, it just zooms in. I can't even get it to zoom back out, the camera is basically unuseable. It's also doing the zooming very slowly, if that helps.
 Any way to tear this thing down? I have a different TRV520 that has a broken Firewire port. I wonder if I transplant parts out of it.
	It could be a different mechanism. Mine was a small rocker type switch up near the eye piece. You push it one way with your thumb
 and it zoomed in, other way zoomed out. It was also pressure sensitive - a light touch and it zoomed slower, etc.
 It "rested" in the middle where the zoom was maintained whereever it was.
 After a while it started to zoom by itself. Here's a discussion where some users are discussing the problem:
 https://community.usa.canon.com/t5/Camcorder-Discussion/Canon-Vixia-Zoom-out-problem-p...lp/td-p/219895
 Maybe you can research further using the camera model, etc,etc.. The way you described it above sounds different. Is it trying to autofocus?
 I think I found the problem. If I sort of open the camcorder up (you need to do this to press the eject button, and the zoom control is attached to this piece, it's a weird thing on Sony camcorders) and then touch the zoom control, it lets me control it like normal. Bad ribbon cable maybe?
	I'm sorry for the insane 5 year necropost but did you ever find a solution to this ?
  Hi8 capture using Digital8 camcorder - Edge color issuesBy memrah in forum Capturing and VCRReplies: 56Last Post: 4th Jan 2023, 10:36
  How to check for damage on a Digital8 camcorder that was dropped.By Vitality in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 13th Feb 2019, 16:01
  Sony Digital8 Camcorder Won't Play PALBy MiniDVLover in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 12th Nov 2018, 15:08
  Digital8 camcorder not playing analog recordings well.By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 11th Jan 2017, 19:10
  If I have a digital8 camcorder, would I need a separate capture card?By videoconverter11 in forum Newbie / General discussionsReplies: 10Last Post: 19th Feb 2015, 07:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
