but same codec without getting artifacts?.
I used to encode my videos using h.265 8bit (default Handbrake h.265 option) then merge them with ffmpeg or avidmux.. 2 weeks ago I found out that h.265 10bit is better so I started encoding my videos using that, the thing is when I try to concatenate my previous videos (h.265 8bit) with my new videos (h.265 10bit) then they become artifact-ed. I can't just re-encode hundreds of hours of videos again it would take me ages with my 6-core CPU and the quality would suffer since I use CRF 23/24.. if there's no solution then the only thing I can do is to stop merging my videos which would be really inconvenient ( and I put everything in one folder and now I can't even know which videos are 8bit and which are 10bit) and wait some years for AV1 to be reliable and then re-encode everything with finding a way to minimize the loss of quality and hoping that I'd have a better CPU by then..
Thanks.
				Results 1 to 16 of 16
	Re-encoding doesn't necessarily mean you'll get artifacts.
 While re-encoding should be avoided when possible, sometimes it's best to just re-encode.
 This is one of those times.
 To verify this is a good idea, where is a sample of both sources?Want my help? Ask here! (not via PM!)
 I know that but I'm not sure you understood me correctly since I'm trying to avoid re-encoding. Here are 3 samples one is encoded using HEVC 8bit and the other HEVC 10bit with HandBrake and the final one is both videos merged with avidemux without re-encoding pay attention to the second half of the latter to understand my problem.
 https://drive.google.com/open?id=1SxJCgLKqtXm6_uFgnIraKFfiQx9ilpMmLast edited by Felow; 2nd Jan 2020 at 16:55.
	Here are the two source files remuxed to TS and concatenated to a new TS using ffmpeg:
 It plays fine in several players I tried. The file won't work properly in some editors.Code:ffmpeg -y -i HandBrakeDefaultHEVC8Bit.mkv -codec copy cat1.ts ffmpeg -y -i HandBrakeHEVC10Bit.mkv -codec copy cat2.ts ffmpeg -y -i "concat:cat1.ts|cat2.ts" -c copy output.ts
	Is there an ffmpeg command to do this with all the files inside a folder? similar to the commands " I have never remuxed files, is there a quality loss? (because I noticed that the merged files using TS have a size of 28,610kb and the original merged files are 26,418kb) finally can mkv be used instead of TS ?.Code:(for %i in (*.mkv) do @echo file '%i') > mylist.txt ffmpeg -f concat -i mylist.txt -c copy output.mkv
 Edit: VLC has trouble reading your file.Last edited by Felow; 13th Nov 2020 at 00:43. Reason: Important edit.
	Remuxing a video file won't mess with the quality, it simply puts it in a new container without re-encoding.
	You can do that in steps. First remux all the source files to TS, then concat all the TS files.
 But I wouldn't do this routinely. Only when specifically needed. As noted, some editors will have problems handling the mixed content. They assume all the video in a file is the same. And you don't have control over the order of the files (you could sort the list after building it and before concatenating).Code:del mylist.txt for %%F in (*.mkv) do ( echo file '%%~nF.ts' >>mylist.txt ffmpeg -y -i "%%~nxF" -codec copy "%%~nF.TS" ) ffmpeg -y -f concat -safe 0 -i mylist.txt -c copy output.ts
 There is no loss when remuxing. It's like taking a cake out of one box and putting it in another box. The cake is unchanged.
	You're right, I should avoid doing this since my main video player VLC has trouble reading the ts file but it works on windows 10 movies& Tv app. Now is there a way to know the bit depth of a video that was encoded with handbrake? all my videos are in one folder and I don't know which is which anymore. Last edited by Felow; 13th Nov 2020 at 00:44.
	Great! MediaInfo works fine but it doesn't show multiple Bit depths if files are merged https://imgur.com/a/SUWnp62 but that isn't a problem.
 So to summarize if someone in the future wanted to do what I asked for in the thread: The only way to do it without re-encoding is by remuxing the files into a TS container then concatenating them and this is best to be avoided since some video players have trouble handling mixed content (VLC does at the time of writing this).
 Thanks for the help.
	... and they will probably fail if you jump back from the 10bit to the 8bit part of the video and most tools for reencoding will also have problems with the content switching between 8bit and 10bit,... Yes, there are lots of things you can do with transport streams and even .avi files, but not everything that is possible should be done for compatibility reasons,..It plays fine in several players I tried.users currently on my ignore list: deadrats, Stears555, marcorocchini
  Why the rippers usually change the original bit of depth (DTS Core)?By Enrik in forum AudioReplies: 10Last Post: 26th Jul 2019, 18:53
  PotPlayer downgrades DTS channels and bit depth?By Zach_N85 in forum AudioReplies: 6Last Post: 19th Dec 2016, 15:08
  How to create VP9 bit depth:10 video fileBy Ling He in forum Video ConversionReplies: 1Last Post: 16th Oct 2015, 07:38
  [No video track found] ffms2 and Cineform (banding, high bit depth)By 4K_ in forum Video ConversionReplies: 3Last Post: 15th Oct 2015, 19:03
  Bit Depth,Sampling Rate used for Uncompressed Audio-Bit Rate for CompressedBy alexander121 in forum AudioReplies: 9Last Post: 4th Apr 2015, 11:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
