I suppose the answer is yes, but.... as the file format of tv recorded programmes cannot even be seen ( let alone read ) through external cables ie. a sata, as they need converting, will they also be invisible if the recorder is connected to my wifi network ? I've connected the machine to my router via ethernet, but the only things that are visible are my external computer drives, a streaming box and my neighbours tablet. My machine has software issues so I can't copy the files to a usb drive ( obviously the machine converts the format to one that's readable externally ), and I can't downgrade/upgrade/re-install the software without first formatting the drive ( another bug, perhaps the same one ). I can watch the programmes on tv, but it would work better for me if I could watch them via wifi. The manufacturer went bust years ago.
is this a dvd/blu-ray recorder of some kind ?? what model ?
if yes, then the files might be encrypted. -
No, it just has a hard drive. The make and model is - Technika 8320.
Why is audio bitrate not visible in MediaInfo or AVInaptic?
By collide in forum Newbie / General discussionsReplies: 4Last Post: 24th Jan 2018, 15:10 -
WMC recorded to different format
By helpful55 in forum Video ConversionReplies: 1Last Post: 17th Jan 2017, 01:38 -
Identifying the file format of recorded TV
By npat in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2016, 11:02 -
Hdmi wifi
By steve2233 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th May 2016, 17:40 -
wifi printers
By vhelp in forum ComputerReplies: 2Last Post: 3rd Aug 2015, 10:16
