What do you think about the following parts for a new budget AMD Ryzen build?
1) AMD Ryzen 5 1600 or 2600 (price difference is not great, but I want Windows 7 compatibility so no integrated graphics or newer Ryzen)
2) ASUS PRIME X370-PRO or ASUS ROG STRIX B450-F GAMING (price difference is not great, but B450 is newer and has HDMI 2.0b even if I will not use it for now)
3) KINGSTON KVR24N17S8/8 8GB DDR4 2400MHZ (least expensive RAM I can find, unfortunately without a heatsink, pair of two for 16GB in dual channel)
Any suggestions are welcome.
	Those cpu's/mb aren't compatible with windows 7 so you need to get a windows 7 iso that's been modified to work with them,there's a long thread here about the iso.
 For choices i would get the ryzen 2600 and asus b450.I think,therefore i am a hamster.
	I believe not compatible with Windows 7 are 2200G, 3200G, 3400G and every other 3xxx Ryzen. Any thoughts about the RAM?
	the 2600 is not compatible with win7.
 - 6 Cores/12 Threads Unlocked
- Frequency: 3.9 GHz Max Boost; Includes Wraith Stealth Cooler
- 19MB of Combined Cache. Maximum temperature: 95 degree C; CMOS: 12nm FinFET
- Compatibility : Windows 10; 64 Bit Edition , RHEL x86 64 Bit , Ubuntu x86 64 Bit
- Supported technologies are amd storemi technology, amd sensemi technology, amd ryzen master utility and amd ryzen vr ready premium
	My 1700x wasn't compatible with windows 7 so i would guess every ryzen was made that way.As to the ram i have always gone with corsair,never gone faulty. I think,therefore i am a hamster.
	Since Win 7 + Ryzen seems to not be a marriage made in heaven:
 https://www.anandtech.com/show/11182/how-to-get-ryzen-working-on-windows-7-x64
 It seems the OP will most likely have to switch to Win 10 (or Linux), in which case he may be better off waiting to see what the new Zen 2 based APUs will bring to the table.
	I am aware of the issues, but from the many posts I read I think it's feasible to install Windows 7 on systems using the specific Ryzen CPUs. I am not sure though if it is a good idea to upgrade, if I don't plan switching to Windows 10 soon. And weren't Zen 2 based APUs supposed to be available by now?
	Zen 2 APUs are scheduled to be officially announced at CES2020, which starts on the 7th.
  AMD Ryzen 3 2200G Quad-Core 3.5 GHz (Raven Ridge) PC buildBy redwudz in forum ComputerReplies: 6Last Post: 22nd Mar 2018, 07:28
  Amd ryzen 3 2200gBy kyrcy in forum ComputerReplies: 5Last Post: 25th Feb 2018, 22:29
  AMD Ryzen 7, Anyone using it?By sum_guy in forum Video ConversionReplies: 6Last Post: 17th Dec 2017, 05:52
  Building AMD Ryzen workstation for video editing on budget?By Hm... in forum Newbie / General discussionsReplies: 6Last Post: 21st Apr 2017, 20:49
  Some absurd AMD/Ryzen rumors to keep you tidyBy sophisticles in forum ComputerReplies: 0Last Post: 5th Feb 2017, 13:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
